Clutch pedal won't move at all.
Discussion in 'Volvo Forum' started by Lethalsmirk, Jul 2, 2016.
  1. Lethalsmirk
    Lethalsmirk Bobtail Member
    14
    Jun 1, 2014
    virginia beach,va
    2010 780 clutch pedal stuck in up position. any ideas??
  3. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    The Master or Slave Cylinder for the Clutch is bad, I would replace both as it's cheap insurance that it won't leave you stranded in the future.
    The piston rod for the cylinder is internally worn out and is not aligned anymore and binding which is causing the Clutch Pedal to be stuck or frozen in the upright position.
    Dave_in_AZ and BUMBACLADWAR Thank this.
  4. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    Yes start with the slave cylinder.You must bleed the air out forever...seems like
    Dave_in_AZ Thanks this.
  5. ryanbob1
    ryanbob1 Light Load Member
    121
    35
    Sep 9, 2016
    does the seat have air? this most likely could be a 4 way valve problem the main valve that supply's air to the vehicle make sure you have plenty of air in all the tanks. then move on to the master cyl then slave cyl
