Clutch or Trans causing my speedometer fluctuate under full load?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by awright, Dec 23, 2018.
  1. awright
    awright Light Load Member
    86
    16
    Dec 20, 2016
    What could be making my speedometer fluctuate under full load. I am getting a grown/vibration at the same time. I feel it is in my clutch or transmission, because I get a shake at high Idle also. My mirrors shake in reverse also. I have had all of drive line balanced. Clutch and reman transmission are about 8 months old.
  3. Dale thompson
    5,305
    45,198
    Nov 20, 2013
    commerce twp,mi
    Did you mean a groan and vibration? The high idle problem makes me think engine miss as in injection or valve train problem
    Newto Trucking Thanks this.
  4. SteerTire
    SteerTire Road Train Member
    1,414
    2,346
    Nov 5, 2018
    Behind the wheel
    Engine mount?
    Tranny mount/cross member?
    Could be one of several things, or a combination
  5. AModelCat
    161,251
    Make/model/year/transmission?
    If its a typical manual transmission the speed sensor is on the output shaft of the transmission. I'd be checking the output shaft and the driveline for movement. I suspect the output shaft could be sloppy and under full load the driveshaft is torquing up and causing the speed sensor air gap to change.
    BUMBACLADWAR, lester and SAR Thank this.
  6. lester
    2,930
    7,925
    Jan 2, 2012
    NW, Iowa
    Check your ride height for the growl and vibration, but obviously that wouldn't cause a vibration at high idle. Did this all come on suddenly?
  7. awright
    86
    16
    Dec 20, 2016
    Thanks for all the replies. I hope I do not have a valve or injector problem. I just had a platinum out of frame overhaul done less than 25000 miles ago. 2007 Peterbilt 379 with cat c-15 625 factory hp with PDI system on it. Reman 18 speed transmission about 40000 miles ago. With new clutch at that time. I have had ride height checked by two different shops, and they say it is in specs. These issues were definatly not sudden. Things have gotten progressively worse over the last couple years. If I didn't have so much money invested in this truck, chasing this vibration/hop. I would have sold it a long time ago before it gave me so much grey hair.
    I feel a hop under light load, and coasting also. Had new rear brake drums put on and balanced 8 drive tires two weeks ago. All this has been going on since before overhaul, clutch, and trans, balanced drive shafts, new dampener on engine at overhaul. I am just grabbing at straws now. I wonder if the clutch has been over stressed, and is now out of balance. It was a factory 2050 torque clutch, and PDI tells me I should be around 2300 now. I just don't now enough about transmissions to know if there is enough fast moving parts inside at Idle to cause a shake. I feel it is clutch, but just don't know how that would make my speedometer jump, unless my ecm/speed sensor are working together to feel slippage, and be over correcting things.
  8. pilewrench
    pilewrench Bobtail Member
    10
    Oct 26, 2016
    check the trans output yoke to see if it's loose. the yoke typically holds the tone ring for the speed sensor as well. if the yoke has come loose, the tone ring can spin on the shaft, causing it to not match the trans output speed, making the speedo dip. depending on the trans, this can also loosen the trans output bearings as well, causing a driveshaft shimmy. the vibration at high idle CAN be a clutch that has broken ears on the intermediate plate, causing it to slop around in the clutch assembly. drop the inspection cover for the clutch, block the whells, set the brake, and see if you can shine a light on the clutch while the engine is idleling. if it's running off center and wobbling, there's the issue.
    good luck, vibrations can be a bear to track down...
  9. awright
    86
    16
    Dec 20, 2016
    I put a new yoke on the back of the transmission a while back, and that was not it. I still have to drop the plate and do a visual on the clutch again. Could the ears being broken on the clutch cause a hop at highway speed also, along with my vibration under load, or do I have two issues. Another wierdo clue to add to this, is that sometimes when I am under full load, and the vibration is going on, my red low fuel light comes on, and my fuel gauge drops to empty, then recovers back to where it is. Is the vibration really shaking things that much. I had some similar symptoms before I had new reman transmission, and new clutch put in, that is the only thing holding me back from trying a new clutch again. I just wonder if the clutch install was not done properly.
  10. awright
    86
    16
    Dec 20, 2016
    If I do decide to tear things apart, which clutch do you guys recommend? I have a Cat C-15, 18 speed trans, with 700hp at the back wheels on the last dyno. PDI tells me I am getting about 2300ft lbs torque. I have a 2050 eaton in now. I have looked at PDI clutch, and Pittsburgh Power is saying Lipe, I have heard Eaton does have a 2250. I just want to put together this time with the rite one. Any good clutch experts/shops you guys have good luck with also?
  11. awright
    86
    16
    Dec 20, 2016
    Back to the Shake problem. I think we have eliminated rear end problems now. Any one have any ideas on how to determine if the shake could be from my clutch or is it something bent in my transmission. I even get a shake when sitting still and at night when sleeping. They work so close together, I am trying to decide, so I can have a clutch on hand before we take things apart to avoid extra down time. Clutch is less than a year old, and transmission is a reman 18 speed at the same time.
