Clutch hydrolic system fluid??????
Discussion in 'Volvo Forum' started by Snailexpress, Aug 3, 2014.
  1. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Is it safe to use DOT4 brake fluid to fill up the clutch reservoir VOLVO 2009. I have add some and liquids are not mixing together. It's stay separated like oil and water.
  3. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    DOT4 is the only fluid you are supposed to use in the Reservoir. If it looks separated, it may be contaminated, you may need to flush the system out and refill.
    Snailexpress Thanks this.
  4. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Thank you boneebone. Tomorrow will drain all s...t and flush with fresh fluid.
  5. boneebone
    2,294
    2,365
    Mar 13, 2009
    If you needed to add some fluid, you might want to check that your Master and Slave Cylinders are not leaking. A sure sign of that is needing to top off the Reservoir constantly. It's Cheap Insurance against a breakdown, because once a Cylinder fails, you are stranded until it is replaced.
    blanco Thanks this.
  6. EHB
    EHB Medium Load Member
    491
    209
    Apr 26, 2011
    Newfoundland
    Could be water(ya hope it is only water)
    If it is contaminated with water is not too bad and flushing the system may fix the problem.
    But if it is another fluid like power stairing fluid, then flushing will not help and the hole system may have to be ripped out and replaced.
    Break fluid is completely different from power steering fluid.
    If it is Smiley then it maybe contaminated with power steering fluid.
    Power steering fluid in a break system will ruin all the break seals including your master cylinders, everthing would have to be ripped out and replaced and is very costly.
    I hope for your sake it is only water.
  7. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    Yep, get it replaced. Slave will eventually fail and leave you stranded. Has happened to me. Also check the hydraulic line for leaks.
