Clutch Fluid KW T880
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by kestrel1, Dec 23, 2020.
  1. kestrel1
    kestrel1 Bobtail Member
    35
    10
    Jan 1, 2009
    Sacramento, CA
    Just wondering what type of fluid to put in clutch reservoir. I have a 2016 T880, I’ve had a few different suggestions, and can’t find anything online or anywhere so just want to see what is correct fluid.
    Thanks
  3. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    DOT 3 Brake fluid
    spsauerland and kestrel1 Thank this.
  4. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
  5. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    Some were factory filled with DOT 4. There were supposed issues with fluid crystallization. There was a bullentin to flush the system and change to DOT 3. As far as I know the only difference is higher boiling point. Fluid will never get that hot on a clutch application anyhow. Nowhere near as hot as a brake caliper.
  6. kestrel1
    35
    10
    Jan 1, 2009
    Sacramento, CA
    Thanks, I’m not sure what is in mine, whatever it is they filled at the factory I guess, I’ve only 96k miles on mine. So regardless of which fluid it is, DOT3/DOT4, if I just top off with one of these, it will be safe?
    Goodysnap Thanks this.
  7. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    DOT 4 is harder to find and more expensive.
    Just stick with your everyday sealed pint of DOT 3 available at any corner auto parts store and youll be fine.
    kestrel1 and spsauerland Thank this.
