I am adjusting the clutch on this truck before it goes into service, and I have exactly half an inch at the release bearing.
The instructions say to adjust the linkage to get the right brake squeeze first.
Then they say to get the right clearance at the release bearing and fork, if I understand correctly, they say to adjust the pedal stop inside the cab.
So my first question is, is that the correct sequence and method?
The second question is, can I adjust the linkage so that the clutch brake is just a little bit higher so I don't have to push my foot all the way down to the floor?
The last question is how do I adjust the pedal stop on an fld120?
Clutch adjustment
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Oct 13, 2019.
Page 1 of 3
If you ever get it where you want it than you normally only adjust pressure plate for more free play.spsauerland and Rideandrepair Thank this. -
With the bearing to brake gap at 1/2". Adjust your linkage to 1/8" fork to release bearing. Put paper in between the bearing to brake for squeeze check. From there you should be able to adjust the stop.
Like @BoxCarKidd says. The goal is to adjust only the internal at your scheduled maintenance.AModelCat, spsauerland, Rideandrepair and 1 other person Thank this. -
Dino soar and Rideandrepair Thank this.
pushbroom and Rideandrepair Thank this.
The Eaton instructions actually say to adjust 1/2” gap on release bearing to clutch brake first, next adjust linkage, for proper clutch brake engagement, 1/2”-1” from floor. And last, adjust forks gap ( freeplay) to 1/8” by adjusting the pedal stop in cab. I did mine though, just as goodysnap said, adjusting linkage, for 1/8” ( freeplay) after adjusting bearing/clutch brake gap at 1/2”. And clutch brake was right on the money. I didn’t want to adjust pedal stop unless it was necessary, figured it was set that way at factory, and should be correct if everything else was. If I changed the flooring, by adding thick wood or insulation, I figure, I might have to make adjustments.
Rideandrepair Thanks this.
pushbroom, spsauerland and Rideandrepair Thank this.
That what clutch brake is there for.
Art Vandelay, BoxCarKidd and Rideandrepair Thank this.
Page 1 of 3
