Cluster fuse
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Aktrans, Dec 27, 2016.
  1. Aktrans
    Aktrans Bobtail Member
    8
    Hello, i am a new trucker to this forum and i have a problem with my 2007 volvo vnl 780 fruse #f20 (cluster and radio) its a 10 amp it started to blow them at first and now its frying it before i even get a chance to push it in place bacsicaly arching once the fuse touches the terminal...
  3. Ristow
    Ristow Road Train Member
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    you have a short in the circuit somewhere. look for a chafed wire. i'd start with the radio harness and plug.
    Aktrans Thanks this.
  4. Aktrans
    8
    Thank you it's kind of obvious:D:p
  5. Ristow
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    have you been in the dash messing around lately?
  6. Aktrans
    8
  7. Aktrans
    8
    No it just started blowing a fuse a day 5 days ago and then now its just frying them befor i even get it in
  8. Aktrans
    8
    This one was bu accident
  9. Aktrans
    8
    Yeah thats the first thing i did is disconnected the radio harness
  10. Ristow
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    this circuit is also tied in with the overhead/dome lights,correct? are there courtesy lights in the door panel? thinking maybe the wiring passing from cab to door has finally chafed thru.
    since you have not been in the dash just prior to this happening,i would look for any wiring on this circuit that passes thru a door grommet or related. anywhere the wiring loom moves,.
  11. Aktrans
    8
    No those are separate from thar fuse
