Clogged fuel filter
Discussion in 'Volvo Forum' started by TruckerS100, Jun 5, 2021.
  1. TruckerS100
    TruckerS100 Bobtail Member
    Jun 5, 2021
    Truck losing power, "check fuel filter" popping up. I replaced the filters already but it's still losing power. What can it be? Volvo 670 with D13 2016
    Reason for edit: Missing info
    Matt1924 Thanks this.
  3. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    Well with that year/make/model/engine it's for sure the.............
    Matt1924, Kyle G. and Cattleman84 Thank this.
  4. TruckerS100
    Jun 5, 2021
  5. Matt1924
    Matt1924 Light Load Member
    238
    529
    Aug 6, 2018
    Georgia
    I've got a 2013 model and was having the same issues last week. I was losing power on grades in higher RPM range intermittently and the next day the "check fuel filter" light came on. I had assumed it might be the issue anyway, and I have another design on the fuel/water separator that isn't see through, so I had that filter and the fuel filter replaced. Turned out it was the problem. I had a nice sludge build up and water in the fuel that I attribute to some bad batch I picked up at a pilot. Had to change filters twice to get that crap out. Might want to keep an eye on that. I was worried that maybe I was having injector/cup issues as it was only happening under load and at higher RPM, but glad it turned out to just be fuel. Volvos are very peculiar when it comes to fuel.
    KB3MMX Thanks this.
  6. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    Treat tanks with full strength biocide like FPPF Killem for slime algae
  7. ONEWAY TRANSPORTATION LLC
    ONEWAY TRANSPORTATION LLC Bobtail Member
    I also had the SA 16 DTC P016F00 fault code pop up on a 2019 VNL 860 with a D13 engine that I recently purchased in Indiana. I know the truck had been sitting from October until I drove it off if the lot on March 7th (with less than a quarter tank of fuel. I figured that it had probably gone bad. After I topped her off in Whiteland IN I made it 40 miles east of Amarillo when the truck suddenly lost power. Not the typical derate where the truck counts down to a 5 mph crawl, but just an apparent loss of power (probably about 40-50%. Bruckner’s Volvo runs the dyno and determines that the fuel filters were clogged. I had them change em’ out (the main fuel filter and the water fuel separator)…both of which are located on the driver-side of the engine inside the frame unlike most that you see that are located outside the frame on the passenger side). Over the next couple of weeks the truck does this load of power thing intermittently but gradually got worse. I had speedco in Kingman change the filters out again and the problem is gone. By the time I completed my 10 hour break the check engine light even went off. Hell of stressful but I glad to know that it’s a simple fix. Just takes some time to get out of the system.
    Peace!
  8. simonsocm
    simonsocm Light Load Member
    109
    64
    Aug 17, 2019
    Yeah, generally when you have something clogging filters like this you'll have to change them again shortly afterwards to get everything left over out.
    77fib77 Thanks this.
