Clearinghouse Registration question
Discussion in 'Trucking Schools and CDL Training Forum' started by RampRat, Apr 9, 2022.
  1. RampRat
    RampRat Bobtail Member
    22
    19
    Oct 6, 2006
    Dallas,Texas
    Hope someone can answer this question for me. I have been looking a several company web-sites and looking at what there requirements are, I saw one that under the requirements section is said " With the Department of Transportation's Drug and Alcohol Clearinghouse in effect, all applications must create a profile at the fmcsa before being hired"
    Do all companies require this? or is it just this particular company.
    Thank you!
  3. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    All companies. Before you can drive, you have to have a negative report from the clearinghouse.
  4. tscottme
    tscottme Road Train Member
    Yes. You need to register at the Clearinghouse.
    Eddiec and Boondock Thank this.
  5. D.Tibbitt
    141,051
    if you have experience driving in the last 2 years. you should already be in the clearinghouse
  6. nredfor88
    nredfor88 Road Train Member
    1,801
    6,096
    Sep 26, 2019
    USA
    Only if he took a job in that timeframe. I don't think you need to register if employment was continuous through the time the rule was implemented, although employers may have asked drivers to do it. Now, of course since he's seeking employment.
    ZVar Thanks this.
  7. ZVar
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    That's correct. Only need to sign up for a new job. If you keep the same job until you retire (and had it when the clearinghouse started) you will never need to register. For the other 99.99999% of drivers out there, they will need to.
    Are CDL drivers required to register for the Clearinghouse?
    Drivers are not required to register for the Clearinghouse. However, a driver will need to be registered to provide electronic consent in the Clearinghouse if a prospective or current employer needs to conduct a full query of the driver’s Clearinghouse record—this includes all pre-employment queries.
  8. Jacoooooooo
    Jacoooooooo Heavy Load Member
    742
    1,049
    Oct 20, 2013
    Hey guys so I just did the first query on myself as an owner operator couple days ago. Unfortunately I missed this dumb requirement before and I’ve been employing myself since 2020.
    How deep in a hole am I with this?
  9. ZVar
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    If you get audited it might come up, but if you keep up on verifying you didn't fail a drug test (yes, it's silly I know) even in an audit it may not be an issue. At this point it's not worth worrying about.
