Clearance lamps
Discussion in 'Trucking Industry Regulations' started by rookiedriver93, Jul 15, 2019.
  1. rookiedriver93
    rookiedriver93 Bobtail Member
    13
    7
    Mar 29, 2014
    Dispatch says I can drive with clearance lamps out during the day. But don't I still risk failing a random inspection and getting a citation ? There is a short somewhere and Love's can't fix it. If I remove the fuse to the clearance lamps , I have turn signals but no lamps. If i replace fuse for clearance lamps , I have those , but no turn signals . Any advice and facts on this issue are appreciated. Thanks.
  3. kemosabi49
    10,435
    44,376
    Jan 13, 2013
    SW Arkansas
    Keep the turn signals working and find a shop that knows their stuff.
    MACK E-6, Rocks, Bean Jr. and 3 others Thank this.
  4. wis bang
    wis bang Road Train Member
    3,348
    3,916
    Jan 12, 2011
    Levittown, PA
    No turn signals/brake lights are both out of service violations.
    Clearance lamps are not required in the daytime and would not be an out of service item during an inspection.
  5. Powder Joints
    7,506
    7,408
    Sep 25, 2007
    Rosamond, SoCal
    Actually they are required all the time, not required to be turned on but if you get inspected they have to work. Not an OS at anytime.
  6. xsetra
    xsetra Road Train Member
    5,092
    6,939
    Aug 21, 2011
    Clearance lights are required to work, always.
    Not an oos, it is a failed inspection.
  7. Rocks
    Rocks Road Train Member
    14,902
    61,101
    Jan 13, 2008
    Somewhere
    Don't know about electrical stuff... But I can say that most dispatchers are full of BS....:biggrin_2552:
    During DOT inspection all lights must be working properly. Can't say for sure if a clearance light failure is a os.
    Go to TA/Petro and have them take a look at it. If it's something they can't repair, they should know where you should go next... Good luck with the repair...
  8. Espressolane
    16,960
    102,188
    Unplug the trailer, see if the problem stays or goes away.
    FlaSwampRat Thanks this.
  9. deathB4decaf
    deathB4decaf Medium Load Member
    605
    872
    Jan 10, 2018
    Confirming, clearance lights MUST be operable during an inspection. Result of non-operable clearance light is a failed inspection, not OOS.
  10. wis bang
    3,348
    3,916
    Jan 12, 2011
    Levittown, PA
    My response was directed at the OP wondering if he could run in the daytime with the clearance lamps off.
    Every light must work on inspection but running during the day with the markers off is commonplace and would not initiate a roadside inspection.
  11. deathB4decaf
    605
    872
    Jan 10, 2018
    While it won't initiate a roadside inspection, it would qualify as a fail if for any reason he received an inspection.
