http://www.cleartv.com/
Thought it was a great buy at that price, picked one up hooked it up and picked up an extra 3 channels ...... 10 instead of 7 with the built in antenna in Cascadia
Clear TV HD Antenna at Loves $12.99
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by albert l, Mar 20, 2015.
Albert, what kind of setup do you have and what does it cost per month?
Clear TV picks up whatever local channels are being broadcast in the area your at. Just hook it up to your tv and scan , no cost to you ... whatever free channels are out there ABC, NBC, FOX, CBS .... etc, etc. Sitting here watching the NCAA basketball in HD
X-Country, Lite bug, Wild Murphy and 1 other person Thank this. -
I have seen some good antennas by winegard. All free TV channels. Just stick it on your window.
Wild Murphy Thanks this. -
If it is not power amplified it will not work very well. I have a similar antenna that is amplied and most of the time I can pick up 18-25 over the air stations. Amplified version is more expensive but if it doesn't work it is not worth much. This is a perfect example of you get what you pay for. All that being said you can get signal amplifiers and stack them to get a lot higher RF gain for the incoming signal. All depends how bad you want to watch TV.
I always wonder about the guys who have the tv satellite dish with them. When they park they just stick the dish outside and I assume they get numerous channels
Some self adjust, others have to be adjusted with a remote.
And it's just like having Dish or DirectTV at home.
