It is my trailer (2016), and I cannot believe how quickly it is losing its newness inside.
I got myself a load that could be called as dirty. Pork sausage casings it was. Had I known, I would've not... Anyway, the product was packed properly and did not even leave too much of a smell (for which removal I already found an appropriate thread). The pallets, however,, left some wet, greasy stains, hopefully more water than grease, I did applied water and dawn dish wash detergent on each individual stain I found in there and wiped it good with a rug using my big foot instead of hands for that matter.
But my essential question is whether the wooden trailer floor can be washed out, just like reefers, without any compromise. I heard that it is not a good idea. But it is all right if done once every few months, am I right or not?
Cleaning wooden floor of a dry van.
Discussion in 'Ask An Owner Operator' started by TallJoe, Apr 13, 2017.
Yes they can be washed. Just need to leave the doors open until it dries out. I wouldn't make a habit of washing it just when needed.
KB3MMX, RustyBolt, Studebaker Hawk and 1 other person Thank this. -
We run some of the dirtiest, dustiest floor loaded raw food on wood floors. Trailer will get washed once a week, maybe once every other week. The important part is making sure its dry before closing the doors. Mold will form quickly in that hot, dark, and moist area.
If you wash it yourself, there is a chemical that needs to be sprayed while washing. This is only for food grade trailers.
I can get the name of the chemical from our washbay if you dont already know. -
I wouldn't wash it but that's just me. I'd toss some kitty litter down and sweep that out then if there was a smell sprinkle coffee grounds and leave them a day or so before sweeping out. Water makes wood expand then shrink when it dries. It won't hurt it the first time and maybe not even the first dozen times but eventually you'll see daylight coming thru small cracks in the floor from frequent washouts. And there went the structural integrity.
gullim007, KB3MMX, TallJoe and 1 other person Thank this. -
I also feel that washing should be very sporadic, almost last resort. I want the trailer to be paid off and serve me long time, so I need to know tricks of a floor maintenance. But wanted to know experiences of others. I know some apply sap to seal cracks, this also harden the floor pretty well, they say. I was wandering if at some point it could be also painted, just like house decks... to preserve it better, and would then such a painted floor be washable without expanding/shrinking after. Floor condition is the most important element of the van's inside, it is what determines its worthiness, I think. Well, roof must not leak either.
If you really want to do it right, do what the bedbuggers have done for years. Sand it down and seal the floor with polyurethane floor sealer. You can make it look just like a basketball court if you want. Yes, it can stand the day to day fork lift use, and you will know it if some jerk spins his tires on the floor. Go to any Kentucky Trailer dealer, they can sell you the correct product, it is a factory option. Some of the trailers we pick up from them are nicer than the average living room.
If anything oily or dirty gets on the floor it is any easy cleanup, doesn't seep into the wood. And you can reapply it periodically.KB3MMX, Ruthless, Cornbinder_King and 1 other person Thank this. -
TallJoe Thanks this.
Concrete penetrating sealer works well on wood.turns it like petrified wood. Deck stains and sealer will either be oil based or water based which will eventually flake. Oil based not good for food. Be sure to spray the under side too.
Keep in mind sealing it will make it slick as owl ####. My trailer came with pro-lam sealant on the first 8 feet of the floor from the doors and it's really slick.
