Cleaning out the air lines?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by razor1983, Mar 13, 2013.
  1. razor1983
    razor1983 Medium Load Member
    500
    509
    Jan 17, 2011
    I recently changed the air dryer cartridge, when one of the valves on the bottom started leaking air. The housing was a mess on the inside, it was really greasy.
    I had to change my air compressor last year and at the same time they changed the governor and the blow-back valve(if thats what its called).
    Today I took off the air dryer and its getting greasy inside again,I've also noticed that trailer couplings are greasy.
    What can I use to clean out the air lines on the tractor and trailer? I've seen air brake de-icers at truck stops but noting that claims to clean out the air brakes.
  3. FLATBED
    FLATBED Road Train Member
    Calgon makes a product called PNEU FLUSH , its used to clean oil / water out of airlines in Commercial & Production facilities. Used it once on the airlines for a live floor wood chip trailer did a good job.
    TheBaron97 Thanks this.
  4. jonboy29
    jonboy29 Light Load Member
    297
    187
    Jul 9, 2010
    Home Sweet Home... SW Ont.
    might try draining the tractor air tanks daily. This will help remove the sludge before it can travel to the trailer.
    It isn't a cure, but it certainly will help.
    The oil should sit in the bottom of the wet tank, but if its getting to the trailer, then its getting to your brake valves in the cab, seat, suspension.... everywhere.
    Might want to get it looked at, especial in this cold.....
    ancient chineese secret..... we need more calgon!!!!
  5. FLATBED
    :biggrin_25524:ancient chineese secret..... we need more calgon!!!!
    CALGON makes a lot more than just DETERGENTS for chinese laundries
    TheBaron97 and jonboy29 Thank this.
  6. Ruthless
    Ruthless Road Train Member
    8,791
    86,006
    Aug 28, 2010
    The City.
    What's the best way to use a product like this? Blow some thru the intake ofthe compressor? Or pull off every line and pour a little in :/ ?
  7. jonboy29
    297
    187
    Jul 9, 2010
    you have to put it into the system after the air dryer, because the air dryer will spit it out, and it won't or shouldn't get past the dryer. Find the wet tank, and pour it in there, but make sure you have zero psi before undoing lines with dirt and debrit in them, use eye protection.
    TheBaron97 and Ruthless Thank this.
  8. Scrapper
    Scrapper Light Load Member
    289
    83
    Jan 19, 2010
    Nashville, AR
    Like karhauler said. You can also put a quart of brakeline antifreeze in all your tanks. It has a lot of alcohol in it and will clean system. Thats what we do anyways. It will fake a lot of time to get all that. But ifs possible. Just be patient. May have to run product and get new dryer a few times. Have a spsre in truck to.
  9. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    As was said you have to drain your air tanks, especially helpful when you are parked on a hill. Just because it has a dryer does not mean you do not get oil and water going threw especially once the volume of the air tanks is compromised.
    Years ago we use to use carbon tetrachloride, it worked great but killed the operator.
    Just a thought!
