So, I got quite abit of oil in my charge air cooler, from the debacle of my N14. I turned it on its side and left it to drain all it could for about 2 weeks now. I know there’s more oil in it and was wondering if y’all would use dish soap and hot water to clean it? Any other methods?
Cleaning oil from a charge air cooler
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Mar 25, 2024.
I took mine to a radiator shop to get cleaned.
Magoo1968, beastr123, blairandgretchen and 2 others Thank this. -
Car wash. Degreaser, soap, rinse, and let dry
Rideandrepair and mile marker 27 Thank this. -
Borax or Cascade dish washing gel pour it in the CAC and let it set 30 mins then flush it with hot water
mile marker 27 and blairandgretchen Thank this. -
mile marker 27, blairandgretchen and Last Call Thank this.
Doing my radiator at home I've used dawn, cascade and purple power. All worked.blairandgretchen, mile marker 27 and Last Call Thank this. -
I've always sent rads, ATA's, coolers etc to the local rad shop. They can flush them out and pressure test them.
Well, if it's only the charge air. Made of aluminum (assuming) measure the size of the bottom intake port. Find a way to plug it. I've used an old intake hose and a cap from the hardware store from the plumbing section. Then grab some good old aluminum brightener. Mix it 50/50 in a 5 gal bucket. Then let it sit for a few minutes. If you're overly concerned about the acid, you can also use vinegar. Regular distilled vinegar, old trick for engine and radiator flushes. If it's a lot of oil, throw a few scoops of cascade in a small bowl. Mix til dissolved.
Once you flush, make sure to set it in front of a heat source to dry a bit. (Won't hurt if you don't, but I don't like water in the chamber.)mile marker 27 Thanks this.
