Cleaning dirty fuel tanks
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Loaderlou, Mar 4, 2019.
  1. Loaderlou
    Loaderlou Medium Load Member
    342
    130
    Feb 24, 2014
    Hi everyone. I’ve been going thru fuel filters quite frequently lately. I noticed my passenger side fuel tank was getting kind of dark inside so I figured I would try a product called Killem. Supposedly it help with the breakdown of algae in the tank. My problem is I’m not getting more than 1500 miles out of my primary since I started using it. I’ve since stopped using it but still having filter problems. Any ideas on how to clean the tanks besides buying a new one? As always thanks for the comebacks.
  3. bavarian
    bavarian Heavy Load Member
    727
    781
    Feb 13, 2014
    Winnipeg
    That's where the #### goes. I don't know if it's worth the effort to take the tank off and wash it. You still have to dry it afterwards.
    In this case, at least you know your treatment worked.
    I've seen an increased level of fuel in the Davco filter after I used Lucas lubricator. Had to change filter only once between services. I stopped using it in fall. Now during this winter, I've noticed in general a lower level in the filter compared to the years before.
    I would just give it two weeks before I rip it apart.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,432
    Aug 26, 2014
    Yes I would try to run it out if the filter cost is not to high. Other things can also cause dark fuel but just one tank?
    Have pressured washed them out on the truck. Make an angle tip for the nozzle and wash it in every direction you can. Use hot water and soap, then rinse. Leave the cap off and the drain plug out. Use a torpedo fairly close to dry out the water.
    spsauerland Thanks this.
  5. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    Most all fuel tanks have a drain on them. If you can find a nice long warm weekend. I’d suggest Getting 20-30 gallon of clean diesel (to get back to the fuel station) run your fuel as low as you can. Let the truck sit as long as you can. Then drain off the sediments, if possible rinse with diesel or a solvent. Fill it with your clean deisel and see if that helps.
  6. Rideandrepair
    17,217
    55,894
    Aug 8, 2015
    I had the same problem a few yrs back. Just keep changing filters. It eventually cleans up. No problems since.
  7. Misesian
    Misesian Road Train Member
    2,078
    3,178
    May 21, 2014
    Nothwest Arkansas
    Rideandrepair Thanks this.
  8. PE_T
    PE_T Road Train Member
    Have you considered the diesel quality where you fuel at? Maybe flash it with a flashlight. It could just be dirty fuel. The other possibility is using a diesel test strip (if they sell them) to verify the purity?
  9. Loaderlou
    342
    130
    Feb 24, 2014
    Thanks for all the comebacks to date. I think the reason for one tank being darker than the other is I replaced my driverside tank a few years ago because no one could weld the crack behind the strap. I dumped the recent filter change into a clean can and noticed some brown flakey material floating in the fuel. Yes I agree about the filters eventually getting the debris out as an economical solution, and the truck seems to run much better after each change, so I will continue with that for now. Once the weather get better I will try some of the other ideas you have given me as a new tank, which mine is a split tank, would cost about $2200 to replace. Right now is salt season and we’re very busy so time is very precious so filters is my best option. As for algae or asphaltene, I’ll go with algae because it feels waxy between my fingers. My fuel looks very clean when I fill up and from a very reputable source. He claims it’s winter treated. So, again, thank you for all the comebacks. I will keep you posted, and anymore suggestions would be appreciated. Keep the shiny side up.
    PE_T Thanks this.
