Cleaning dirt out of heater core box
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Gumper, Mar 10, 2018.
  1. Gumper
    Gumper Road Train Member
    1,554
    3,628
    Jan 7, 2018
    Butte, MT
    The heater doesn’t blow very hard in my W900, so I tore into it. The fans blow plenty of air, but the heater core looks like it’s packed with dirt. Is there any good way to clean all the crap out of the heater core without pulling it out of the truck? I was thinking of some Dawn soap in a spray bottle, then rinse it out with the hose. There supposedly a drain on the bottom of the box, but it’s probably plugged. Thought maybe I could drill a hole for a drain, and put a rubber plug in it when the job was done. I have found that there’s a special foaming “coil cleaner” for jobs just like this, but no stores around town have ever heard of it. It’s something I can order, but was hoping to get the job finished this weekend.
    KB3MMX Thanks this.
  3. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    Lowe's usually has the coil cleaner..
  4. rolls canardly
    rolls canardly Road Train Member
    1,598
    3,727
    Feb 7, 2009
    mt. pocono. pa.
    First, you're talking about air flow - fan blowing across/thru core fins, not fluid flow inside, correct?
    For the air flow:
    Heater core is just a little radiator; can't you take an air hose and blow thru it? (Wear a dust mask.)
    Sure, you're gonna make a mess, just cover your stuff w/giant garbage bags,
    cut them and duct tape if you have to, but most is fine road dirt that we get into anyway, nothing toxic.
    I did something similar when I changed my cabin filter and found all kinds of crap in there.
    I took one of those giant 3 foot fans, on high, and opened both doors to minimize what settled in my cab.
    Not too bad, also periodically blow hose around inside - often - to keep crap from settling inside. You can add a shop vac near the exit to capture more of the mess, too.
    I think if you wet it - it will just be harder to get out. JMHO.
    Then you can Armor-all the stuff you were meaning to clean in there anyway from winter.
  5. Gumper
    1,554
    3,628
    Jan 7, 2018
    Butte, MT
    We don’t have a Lowe’s here. Would have to drive 80 miles, so I’d be better having it shipped.
    I am talking about the outside. Maybe I can blow it out with air, and wash it after the large chucks are gone. I’m afraid blowing it would send dirt and crap into the interior vents making more of a mess.
  6. Expeditor
    Expeditor Medium Load Member
    451
    530
    Mar 5, 2018
    I would take the air cleaner out and use a vacuum on it. I would not use water while still in truck, There is no way from preventing water from getting inside truck. If you want to use water I would use 2 hose pinching pliers to pinch off the heater hoses and remove the heater coil and clean it very good with water, outside of the truck. The foam cleaner I use comes from a plumbing, heater and A/C supply house, the foaming stuff is very strong acid based. They sell a green one that is not acid based but does not foam as much.
  7. p608
    p608 Road Train Member
    2,181
    2,991
    Nov 10, 2016
    Whether you blow it out or rinse it out go in the opposite direction of the air flow so that you are pushing the dirt back out instead in. there is a drain in the bottom of the box, if you think it is plugged open the hood, find it and clean it out.
  8. rolls canardly
    1,598
    3,727
    Feb 7, 2009
    mt. pocono. pa.
    How accessible is it from outside the truck? Is there room to maneuver?
    I do like Expeditor's idea of the hose pliers - to pinch hoses off and totally remove.
    Then I would just blow it out with shop air.
  9. Gumper
    1,554
    3,628
    Jan 7, 2018
    Butte, MT
    The heater core isn’t too easy to get to. I think he AC evaporator has to come out to get to it.
  10. p608
    2,181
    2,991
    Nov 10, 2016
    Only takes a minute to pull the cover and look
  11. Gumper
    1,554
    3,628
    Jan 7, 2018
    Butte, MT
    The cover has been off since I posted asking about cleaning it yesterday. The AC is directly in front of the heater core. That would have to come out first I imagine.
