Cleaning a fuel tank
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gafred99, Feb 13, 2017.
  1. gafred99
    gafred99 Light Load Member
    155
    12
    May 28, 2009
    Tignall
    I need to clean an aluminum fuel tank (empty) of some algae, some suggestions on a process would be appreciated.
  3. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,376
    Jul 16, 2012
    Bentonville Arkansas
  4. Shock Therapy
    Shock Therapy Road Train Member
    1,259
    28,017
    Feb 4, 2016
    n.cntrl il
    A friend of mine had this problem and he said that he got some additive to put in the tanks, he couldn't remember what it was and either got it at a truck stop or a truck shop, but he also said to take plenty of fuel filters with you as he changed five in ten days, results may vary.
    gafred99 Thanks this.
  5. gafred99
    155
    12
    May 28, 2009
    Tignall
    I plan to shove in plenty of additive with diesel once I get the tank clean, it is empty now looking for a method to wash out rest of the sludge before i fill it. I think a pressure washer will just smear it all over that's about it.
    J.S. and Shock Therapy Thank this.
  6. Shock Therapy
    1,259
    28,017
    Feb 4, 2016
    n.cntrl il
    I do believe the additive was specifically for algae from bio diesel.
  7. kitCat
    kitCat Light Load Member
    97
    38
    Oct 13, 2013
    its made by fppf its called killem
    gafred99, Ezrider_48501, ExOTR and 2 others Thank this.
  8. Dirty-Low-Walker
    Dirty-Low-Walker Medium Load Member
    359
    543
    Dec 17, 2013
    You will need to know what type of algae you have first.
    I had the orange type in my chipper and and removed the tank and flushed it myself with alcohol, which didn't work so i went to a boat fuel tank builder and they flushed it and it never came back.
    the other type i have heard of was black but cannot remember what it was called.
    gafred99 and Shock Therapy Thank this.
  9. A21CAV
    A21CAV Road Train Member
    1,848
    2,156
    Oct 4, 2011
    Laredo, TX
    I just googled 'diesel fuel tank cleaning' in your area and got several hits of companies that come to your location to clean tanks. This is a fairly standard service for stationary engines and large boats.
    Frank
  10. UsualSuspect
    UsualSuspect Road Train Member
    1,257
    1,979
    Aug 14, 2016
    Yo Mama's
    I just went through this with my C7 ACERT, I used Hammonds Biobor JF Diesel Fuel Treatment (I get it from Amazon), put it in the tank before I cleaned it, started the truck and ran it for a few minutes, wanted to clean the lines also. Let it sit for 3 days, drained fuel from tank, and all the sludge and dead crap with it. I had the tank steam cleaned, but you have to remove it, they need to get the wand inside. Change the filters, and keep a fresh set handy, The stuff will clean out the lines, and it will plug the filters, depending on how bad it is. I had to change the filters on mine twice. I now use the stuff every few months to make sure I don't have the problem again.
  11. Volvo8873
    Volvo8873 Light Load Member
    239
    145
    Apr 27, 2016
    Western Wisconsin
    I used the power service biocides. When I got the disease I put about a shot full in every fill up which is about 150 gallons. Took about about 3 months and 15 davco filters. I had it real bad. Now I haven't changed my davco in almost 20000 miles! Lol
