Class B Weight questions
Discussion in 'Trucking Industry Regulations' started by Svoray, Apr 17, 2011.
  1. Svoray
    Svoray Medium Load Member
    558
    194
    Feb 3, 2011
    Texas
    I've got a Class A CDL but I took a Class B job driving a bobtail tanker hauling diesel. It's got two tanks that holds 2000gls each which is roughly 28,00lbs (7lbs per 1gl of diesel) fully loaded. I'm pretty sure fully loaded would be over weight but I'm not sure what the weight limits are on a class B. So does anyone know how much I can legally haul including the tractor?
    Thx for the help
    Ray
  3. Yatista
    Yatista Medium Load Member
    479
    206
    Jan 25, 2009
    Upstate New York
    Look at the factory label on the door jamb. It will state the max axle weights for each axle and your registration will state your max registered weight. Those define the weight limit for your truck.
  4. Crash935
    Crash935 Medium Load Member
    329
    163
    Sep 8, 2007
    Wyoming Mi
  5. Svoray
    558
    194
    Feb 3, 2011
    Texas
    It's got twin dual axles in the rear.
  6. Scalemaster
    Scalemaster Heavy Load Member
    808
    1,717
    Mar 13, 2011
    Midwest
    There are no weight limits on a Class B CDL.
    Single unit CMV's have several areas of weight limit:
    - axle weight
    - bridge weight (axle spacing)
    - tire rating
    - license weight
    - max lading (specification cargo tanks)
  7. Svoray
    558
    194
    Feb 3, 2011
    Texas
    Thx!
    Well I finally found the registration papers..some idiot put then in the side box. Just need to find out my axle limits (which oddly enough isn't posted in the dorr jam).
  8. Bent Wrench
    Bent Wrench Medium Load Member
    588
    205
    Aug 11, 2009
    Cornholio, OR
    If it is class 8 common axle weights would be 12k front and 36K rear for dual tandems, however it may be permitted for more.
    Check tire rating?
    Have you weighed it?
    The driver is responsible for the weight and will be ticketed if caught over.
  9. dieselbear
    dieselbear Road Train Member
    1,798
    2,800
    Oct 18, 2008
    I guess it's a straight truck with a tank? How many axles do you have? For example do you have 3 axles consecutive on the rear (tri-axle)?, and a steering axle for a 4 axle unit? Without knowing how many axles and what the spread is, their is no way to tell you a legal weight. Not sure what every State allows, and if you run in only one State, you may want to contact their weight enforcement personnel and/or the lead MCSAP Agency for that State.
  10. G/MAN
    G/MAN Road Train Member
    7,031
    8,621
    Sep 3, 2010
    Check your cab card. It should list the weight for which you are permitted.
  11. dieselbear
    1,798
    2,800
    Oct 18, 2008
    That is only the allowed registered weight. It will still have to abibe by statutory weight limits, i.e. axle weight and bridge law.
