If you have a Class A with an Automatic Restriction- does it carry over to a class b?? If so do you have to take another driver test to remove it (for Class B)- ?? Can you have non restricted class b with an automatic restricted class a
Class A Restriction Carries Over to Class B
Discussion in 'Questions From New Drivers' started by Mtloaf, Sep 3, 2020.
You have one license. The type of vehicle driven doesn't matter for restrictions. If you have a Class A with an auto restriction, then you have a Class A with auto restriction. You cannot drive any CMV with a manual.
If you go get retested, your license will reflect the vehicle tested in. I.E. if you test in a straight truck with a manual, you will no longer have the auto restriction. You also cannot drive a semi, or any CMV with a trailer over 10k lbs as a Class A is required, and you no longer have.otherhalftw and Wasted Thyme Thank this. -
I have had a Class B here for 15+ years, and upgraded to A in the last week. What a fiasco. Showed up in my one ton (gvwr 11500) and a 35' GN (gvwr 25k), valid for class A. They said that by using this combination for the A, I will: 1) lose the airbrake even though I've had airbrake forever, be auto only restricted, no manual, and no tractor-truck. I fought the airbrake for a few days with them and finally was able to keep the airbrake since the class B vs A airbrake system is basically the same except for glad hands and another parking brake knob for the trailer. But I did get the no manual transmission restriction which sucks because now I cant drive the old 65 international fire service bus...
To keep everything, at least from B to A in my case, I have to show up in a manual tractor with any trailer over 10k gvwr. -
SeeJayneRun Thanks this.
Seems like you only need to turn some miles and get used to the truck. Then learn to drive a standard personal vehicle. I recommend a Dodge from the mid 90's with a cummins. They are highly sought after so you can resell it easily if you want. Yet they drive better if you learn to double clutch.
So learn it on a personal vehicle (if you dont know how to do it already). Then go see an examiner and ask them if you can get the restriction removed if you show competency on the pickup.
Road testing in an autoshift is not smartXray4 Thanks this. -
Xray4 Thanks this.
