I saw at the TA in Albert Lea,Mn a microwave that plugs into the dash plug & am wondering if anyone has tried this (new thing)? as it is the 1st time I have seen it.?
Cigarette Lighter Microwave
Discussion in 'Questions From New Drivers' started by Bumpy, Dec 22, 2010.
I bought one on clarance (wavebox) have no plugs yet so cant tell you how it works but the plug into a lighter i dont see working very well most lighter socets are not 20 amp rated and i would assume it is starving the microwave of power shorting life of it or over heating wiring
Kansas Thanks this.
Junk. Never owned one but used one and to say the least will take you three #### hours to heat up something that only requires a minute! lol. Inverter and standard house microwave indeed is the way to go. In fact you might even like using a George Foreman even better if you have a good fridge.
I know some companies don't allow inverters so this would be better than nothing. It would take a long time to heat even something small using the outlet though. -
like the others have said, best to just get a real good inverter, have the mechanic install that, then go with ordinary household appliances...
may be the 'cheapest way out", for long life items...????Bumpy Thanks this. -
8 to 10 years ago I picked up a brand new 12 volt microwave in some trading, after reading the instructions I decided not to use it.
it was a road pro & its still sitting in my spare bedrooms closet, it used 4 gauge cord, & pulled quite a few amps, plus it would cut off in 20 minutes to not overheat? it was rated at 600 or so watts, but I just wasnt happy with the instructions, so I bought a 600 watt 110 volt microwave, & a 750 watt inverter & used it in my camper.
besides a microwave & cooler/ fridge, my next favorite appliance is a crock pot.
as everyone has said, the best thing is a 110 volt & an inverter, or a portable inverter, & if it is to be used in a personal vehicle I almost would recomend a spare battery, & if spare battery is hooked to vehicle use an isolater to not pull your main battery down. that way appliance only runs on 1 battery & the other sill always be ready to crank you.
Randy
