Chrome 3 position low-direct-od shift knob A-4487on a RTO14613
Discussion in 'Trucks [ Eighteen Wheelers ]' started by beemergary, Dec 15, 2017.
  1. beemergary
    beemergary Light Load Member
    229
    112
    Apr 11, 2014
    Can this be done? Can"t find an air diagram or want to buy it to find out won't work. Can find a diagram for an A-4900-A-6913 newer knobs. Eaton shows it for 12513 and 9513 trans. Found articles where guys used the knob with air line changes but didn't say they had a RTO 14613. If I knew how the air flowed could figure it out.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    How many air lines are on your current shift knob? 4 I thank?
  4. orfordguy
    orfordguy Light Load Member
    56
    47
    Jan 21, 2017
    My 13 in my I'd 900a has that knob.. had 5 lines when i took or off.. still have it somewhere.. see of its labeled when i get home.. tommorrow.. current shifter head is 4 hose and bleeder line.thing you'll need a t fitting underneath.
  5. wore out
    wore out Numbered Classic
    15,319
    184,959
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    The chrome knob uses 3 lines. The slave valve for it became obsolete. If you still have a 12513 and the slave shoots craps you have to update to the new style knob. The slave valve difference is why the 14613 trans used the push pull knob clamped to shifter and just a direct over chrome round knob.
    All that said if you can find a 12513 with the 3 position knob and good slave valve you can achieve your goal. Yes I have done it
    SAR and Oxbow Thank this.
  6. orfordguy
    56
    47
    Jan 21, 2017
    I have both still mounted in the kenworth right along with the big cam 400 and rto13..
