chicken lights
Discussion in 'Peterbilt Forum' started by Chris Nelson, Mar 3, 2016.
  1. Chris Nelson
    Chris Nelson Bobtail Member
    Mar 3, 2016
    I have a 06' 379 short hood. My chicken lights in front of the air breathers and above the steps that run along the cab and sleeper went out while driving. I can't seem to locate the problem. Any help would be greatly appreciated.
  3. Straight Stacks
    Straight Stacks Paper Cha$er
    2,930
    20,768
    Jul 18, 2015
    Alabama Gulf Coast
    Did you pay yer light bill this month?
  4. Chris Nelson
    Mar 3, 2016
    Hardy Har Har nope
    Straight Stacks Thanks this.
  5. Straight Stacks
    2,930
    20,768
    Jul 18, 2015
    Alabama Gulf Coast
    Did you check the terminals on the back of the switch? Sometimes they come loose...power coming in, but not going out. So many variables with old factory wiring...I use to leave that up to someone more capable when I owned a 379...didn't want to fool with it.
  6. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    Get a test light and start checking for power
  7. Nitemare13
    Nitemare13 Light Load Member
    205
    199
    Feb 24, 2014
    Hudson, Fl
    Connections get salted and corrosive. May need pull em apart clean and reconnect. Or could be a bad fuse?
  8. Luwi67
    Luwi67 Heavy Load Member
    746
    484
    Oct 24, 2012
    Long island
    Also depends on who installed them. I've seen set-ups that range from "How can this even work" to "How did this not fry the entire electrical system"
    Cottonmouth85 Thanks this.
  9. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    Start checking to see if the grounds have a good contact that are part of that wiring.
