Checking your Oil
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Richter, Apr 19, 2014.
  1. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    So, i've heard several different time to check oil and wondering what is best.
    Some say, 5 min after a drive while it warm but sunk back in. some say it take a night to sink back in an check after stuck has been stopped for a while. So when is the most accurate time to check oil? Also, do you add when it get to bottom line? I have been adding half a gallon when it gets half way down.
    Also, if you own a detroit s60 14l (with EGR) what do you get for idle oil pressure once warmed up? What do you get during a hard pull up a hill?
  3. realsupatrucka
    realsupatrucka Road Train Member
    2,072
    513
    Sep 25, 2013
    houston tx
    Ill do after the truck has been running about 5 minutes then I cut it off and check it
    Richter Thanks this.
  4. misterG
    misterG Road Train Member
    2,884
    8,981
    Jan 21, 2009
    ask my dispatcher
    I always do a cold check. Or as cold as possible. This gives a better, IMO, read on oil level.
  5. MJ1657
    MJ1657 Road Train Member
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    According to the Cirius/XM snake oil salesman that airs on Saturday and Sunday afternoons adding a half gallon of oil at a time can cause a truck to consume more oil than normal. He says you need to wait until it needs a full gallon.
  6. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
    Add/check it whenever the motor is off, it's Not rocket science.
    snowblind, jbatmick and MJ1657 Thank this.
  7. realsupatrucka
    2,072
    513
    Sep 25, 2013
    houston tx
    dont if you check it while its on it give you a false reading
  8. Jokingypsy
    Jokingypsy Medium Load Member
    669
    613
    Jan 4, 2013
    Dont forget to taste it, if it tastes burnt it needs changing !
    Adam
    ( you probably should not try this without first getting special API / American Petroleum Institute training )
    1029384746 and bergy Thank this.
  9. wore out
    wore out Numbered Classic
    15,335
    185,110
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    As long as truck is level and been shut down long enough for oil to run back into pan it's fine. The difference of 5 minutes or all night isn't gonna matter much, if it does you have serious drain issues internally. Oil temp effects it a little but not enough to matter. I wait to add till they are at the add mark. As long as the oil is within the safe mark oil pressure shouldn't be effected. The amount of oil pressure isn't as important as consistency. What I mean is your motor may have 50 psi at X condition. The motor built right after yours may have 40 at the same condition and be fine. If they loose more than 20 psi or so from first start idle to warm idle with fair outside temps I'll call it then you may have reason for concern. Loosing oil pressure in a pull doesn't sound good either
    RubyEagle and Richter Thank this.
  10. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Mine starts at 55 cold....drops to 46-48 under cruse, drops to 45 under a harsh up hill. drops to 28 at idle after warmed...my idle pressure concerns me so i norm bump up to 900 rpm.
  11. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    The proper time to check the oil level is when it is cold, you check the coolant, the engine oil, the PS fluid.
    As the oil warms up it expands, 5 to 10 minutes is long enough if you need to check it when it is warm. Opening the hood, cools it down a lot quicker, if it is at the ADD mark, when hot/warm fill to the full mark.
    You should keep a record of the fluid use every day, after an oil change the oil use should be very low as the oil gets dirty, the engine will use more, that is the maximum 1/2 life of the oil.
    If you check the oil daily, when cold, I believe you should keep it at the 1/2 way mark, between add and full.
    Just a thought!
