Checking driveline angles
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Collie, Aug 25, 2019.
  1. Collie
    Collie Guest
    Want to check driveline angles in triaxle truck peterbilt.
    I will use a digital angle finder.
    What to look for and what is procedure. How many degrees is acceptable from trans to front diff. Then front diff to rear diff. Thanks you
  3. jamespmack
    213,287
  4. jamespmack
    213,287
    I have a better worksheet someplace
    I'll try and find it. Check spicer website. I have to use it everytime because honestly never have had to measure more than a few in my life yet.
  5. Collie
    Collie Guest
    aw man thanks i appreciate it
  6. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    Eaton driveline angle analyzer is the best tool, however it is 500$ or so. There is other free online calculators.
    If its a tri drive it is probably air trac. Air trac should be 4.5 on both front diffs then 9 on the rear.
    Any reasons as why you are checking angles?
  7. jamespmack
    213,287
    That's is a steep price, dont recall but I thing for about 100 bucks I bought a magnetic digital angle finder. But you have to do the math on paper.
  8. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Yup ^^^^^^^^^^^^^
    Engine/trans angle is 1-2 degrees.
    Make sure you set ride height to spec before measuring angles.
    Dino soar and pushbroom Thank this.
  9. Collie
    Collie Guest
    yup air trac.
    I fiddled with my leveling valve.
    I used peterbilts printout to adjust the valve measuring ride height by measuring tire height and all that. I went off spec and my truck has always rode at 10" . Peterbilt says it should be about 11".
    11" is way to high and creates driveline noise. At 10" it is quiet. I checked it not once but twice. I even checked at the centerline of axle tube to bottom of frame to connfirm peterbilts method.
    So just checking driveline angles as well.
  10. Collie
    Collie Guest
    truck has lift axle. no drive. just 2 rear diffs
  11. pushbroom
    1,777
    7,253
    Sep 1, 2012
    Lift axle doenst matter. It gets set by itself. Truck is a tandem drive for calculation purposes.
