Checking brake lights for pre-trip
Discussion in 'Questions From New Drivers' started by acik1983, Jun 18, 2016.
  1. acik1983
    acik1983 Bobtail Member
    22
    Jun 15, 2016
    Good morning everyone,
    Just wondering how everyone (solo driver - no team) checks their tractor and trailer brake lights for a pretrip?
    Thanks in advance!
  3. Tac-Lift
    Tac-Lift Light Load Member
    54
    58
    May 22, 2012
    Turn on the headlights, turn on the emergency flashers, then start your walk around and look at all the lights as you go.
  4. ExOTR
    ExOTR Windshield Chipper Extraordinaire
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    I use a weight that holds down my trolley valve. I've seen other people use an piece of dowel rod between the pedal and the steering wheel.
  5. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    I have a ball peen hammer that will hold to the trailer trolley valve on the dash and hold it down. You can also get some wire and something heavy enough and fix it where it will hang and pull down
    FozzyNOK and bottomdumpin Thank this.
  6. ExOTR
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    Some company trucks actually have a light check button on the dash, will cycle through everything while you walk around
  7. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    On a Mack, the brake lights come on with the low air buzzer. As it airs up after firing it up, I turn on the 4-ways and walk around the truck. When I hook to a new trailer, I pull down on the hand valve and walk back to check.
    j_martell, Gunner75 and bottomdumpin Thank this.
  8. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    Mine are easy to check,because it's always 2am still dark. Pull trailer out by ween 2 other trailers and see the reflections on each side.
    48Packard, pattyj and Whiteline64 Thank this.
  9. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    Eh.....
  10. brsims
    brsims Road Train Member
    5,296
    6,521
    Aug 8, 2009
    Meadville, PA
    Lights!?
    Where we go, we don't NEED no steenking lights!
    bottomdumpin Thanks this.
  11. Alaska76
    Alaska76 Road Train Member
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    I drive flatbed, so I use the weight of my bar [​IMG]against the brake pedal, then walk back and take a look at the lights. Oop's, sorry, I mean winch bar.
