checking and adjusting trailer brakes
Discussion in 'Experienced Truckers' Advice' started by Truckermike28, Jul 18, 2014.
  1. Truckermike28
    Truckermike28 Bobtail Member
    22
    Biddeford,Maine
    Hello all
    So I have a question here a Co worker and I have an argument going I say you need to check and adjust your trailer brakes weekly he says no he Tells me you check them weekly you never should have to adjust them and if you do there is something wrong with them lol and he says slack adjusters never need to be adjusted to. Now mind you we haul 80 thousand pounds loads and we are local drivers who stop and go alot can you help and settle this who is right and wrong here thanks mike
  3. rbrtwbstr
    rbrtwbstr Road Train Member
    3,334
    7,601
    Jul 11, 2012
    in the bush somewhere
    If you have automatic slack adjusters you should not have to adjust them. If they do need adjusted, they are faulty and should be replaced. But they still need to be checked regularly for slack. We also haul 80k locally, and rarely do we need to adjust them. But when the brakes are replaced so are the slack adjusters
  4. turnanburn
    turnanburn Medium Load Member
    628
    270
    Jan 25, 2011
    central Vermont
    Checking and adjusting are two different things. Out of adjustment brakes need to be brought to specifications before you drive. Not weekly, but before you drive(hint hint:pretrip) Automatic slack adjusters needing chronic adjustment need to be replaced. FMCSA regulations require you to check/inspect your brakes before you drive(hint hint:pretrip). Adjustments are to be made by an individual who is credentialed as a brake adjuster. Many drivers adjust their own, many companies don't allow drivers to do adjustments.
  5. DustyRoad
    DustyRoad Road Train Member
    1,540
    17,104
    Feb 23, 2011
    Gulf of Mexico
    Self adjusting brakes need inspection ( most trailers are equipped today has them) you could be given a ticket for improper adjustment because you were too lazy.
  6. Truckermike28
    22
    Biddeford,Maine
    Now I am talking minor adjustment I am not talking adjusting everyone just the ones that need to be sometime they don't need to be adjusted at all but we check them for the reason that indeed that they could need to be adjusted just cause they need need adjustment does not mean they are bad
  7. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    if they don't adjust. they are bad. eND of duscussion.
    mine are adjusted daily. when I have a trailer or truck that isn't working.
    I don't put up with loose brakes. and I'm certainly not getting put out of service. Cuz you never know when you might get inspected.
  8. rank
    rank Road Train Member
    9,916
    113,498
    Feb 11, 2010
    He is more correct than you. As mentioned, they are supposed to self adjust but many times they do not because:
    1. Lack of grease
    2. Driver doesn't use the brake hard enough or often enough
    3. They are just plain broke
    4. Linings may be worn
    You can get in the habit of checking your drum temp every once in a while. Drum should be more or less the same temp. If you have a cool one then something is wrong and you need to look further.
    However, you can adjust them manually as a temporary fix. One time I got inspected in NY. DOT cop measured and told me that I had too much stroke on one brake chamber and he would have to put me OOS. I asked him to let me crawl under there and manually adjust it to spec. He let me do that and instead of charging me with too much stroke and putting me OOS, he was a good guy and changed the charge to "non operating auto slack". Still a ticket but not OOS. Way better.
  9. Truck Smarter
    Truck Smarter Bobtail Member
    30
    17
    Jun 26, 2014
    Dallas, Texas
    In conversation with a DOT inspector once he remarked that the most common ticket he wrote was for brakes out of adjustment where the automatic slack adjuster had quit being automatic and nobody checked. Checking brakes every day is a good idea. Back before auto adjusters everyone crawled under their truck as a matter of course. It was part of the job. Automatics should not need adjusting if they where properly installed to start with. Once set up they maintain adjustment based on stroke length not on how hard you apply the brakes. If a brake with an automatic slack needs adjustment then the slack adjuster needs to be replaced. Period. And proper installation of automatic slack adjusters is critical in order for the slack to work properly. The manufacturer puts that instruction sheet in the box with the slack adjuster for a reason.
    fuzzeymateo Thanks this.
  10. fuzzeymateo
    fuzzeymateo Heavy Load Member
    771
    783
    May 20, 2013
    AZ
    If it were up to me there would be no auto-slack adjusters... Only manual, and like the old days, drivers would be responsible for adjusting them or having them adjusted. With auto you are supposed to replace them if they are not adjusting properly...There's nothing easier than manual slack-adjusters, it just takes someone with a little bit of sense to adjust them; but then again, that's asking a lot in today's trucking industry.
