Check engine, stop and oil light
Discussion in 'Freightliner Forum' started by Freightliner-2013, Jun 2, 2016.
  1. Freightliner-2013
    Freightliner-2013 Bobtail Member
    10
    I have freightliner cascadia 2013 dd15, this problem I had over a month now, I usually start my day normal run the engine 7 to 10 minutes than start running my shift, every time I bring my truck to stop and do the downshifting to low gears I found this 3 light come on , if I bring the rpm above 10rpm it will go, and if I stay in traffic light a long time the truck will shut down on me . I never have this problem before please let me know what that could be?
  3. CJndaTruck
    CJndaTruck Road Train Member
    3,348
    3,364
    Nov 21, 2014
    Knoxville, TN (area)
    You have had this problem for a month and haven't taken it to get fixed? I don't know where to begin.
    spyder7723 Thanks this.
  4. upallnite
    upallnite Light Load Member
    165
    115
    May 15, 2010
    Hempstead,TX
    find a dealer now. You are having a problem that needs attention now. Be responsible and stop driving that thing before you get yourself or someone else in a bind. Think driver think!
    CJndaTruck Thanks this.
  5. Freightliner-2013
    10
    I have a problem with my truck :) thanks for this advice you know I didn't know that
  6. spyder7723
    spyder7723 Road Train Member
    15,467
    25,010
    Mar 31, 2013
    sarasota, fl
    Certainly sounds like an oil pressure problem. It's dropping pressure at idle triggering a code, then revving the engine up gets the iolite pressure just high enough to prevent a shut down.
    What does your oil pressure gauge read when this light comes on?
    Hopefully it's just a bad sensor. If it's a true oil pressure problem, you have ruined the bearings by running it for a month. Any day now those bearings are going to be so thin they break and you wipe out the crank and block.
    CJndaTruck and Freightliner-2013 Thank this.
  7. Freightliner-2013
    10
    I
    If you know what is that could be say it and share it, of you don't know :) don't even get your self tired and mention anything :)
  8. Freightliner-2013
    10
    I will get my attention about the oil pressure gauge from now and I will be posting that to you, also I will try to look more about the problems cousin by this sensor thanks a lot
  9. TAfool
    TAfool Medium Load Member
    631
    850
    Dec 8, 2012
    Worn bearings allowing excessive flow. Worn oil pump can't build enough flow.
    Cracked oil distribution manifold allowing leakage.
    Lots of problems it could be. Low oil pressure if ignored will lead to very serious motor damage.
    It needs fixing asap.
    TA
    Freightliner-2013 Thanks this.
  10. Freightliner-2013
    10
    I am at freightliner dealer now
  11. SLCTrucker
    SLCTrucker Medium Load Member
    404
    199
    Jan 15, 2009
    Salt Lake City UT
    If it's a DD15 its most likely a bad "O" ring on the oil suction tube in the oil pan....
    B Mac and Freightliner-2013 Thank this.
