Check engine plus derate engine
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bigfletch, May 21, 2014.
  1. bigfletch
    bigfletch Bobtail Member
    18
    Dec 25, 2011
    henderson, tx
    I have a 3406e 2ws. And while driving my check engine light will come on and my engine will derate to about 1500 rpm. Oil and temp gauges show everything is good but I noticed when my water temp gauge gets close to 200 it does this. If I run the engine fan I don't have a problem. I leaning towards the coolant temp sensor. Any other suggestions?
  3. maggard359
    maggard359 Medium Load Member
    476
    413
    Nov 20, 2013
    Florida
    run your flash codes and see what it gives you. turn key on hold cruise set until it starts blinking. Count blinks...pause count blinks. It will be a two number code.
  4. g7ster
    g7ster Bobtail Member
    13
    May 21, 2014
    I agree with maggrad run your flash codes and from there start to trouble shoot the problem.
  5. bigfletch
    18
    Dec 25, 2011
    henderson, tx
    Came up with code 46. I replaced the oil psi sensor and seems to be running fine now. That's for y'all help.
  6. g7ster
    13
    May 21, 2014
    Good to know that its all good now. Keep safe.
