Check brake ECU next stop
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Nodirxon, Nov 30, 2013.
  1. Nodirxon
    Nodirxon Bobtail Member
    Hello,
    I am a new driver and have no knowledge about fixing. Volvo'06 says CHECK BRAKE ECU NEXT STOP. It happened right after I dropped my trailer off and drove about 150 miles.
    Also, ABS light is on.
    Could you please, give me any idea what it is?
    Thanks a lot.
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,733
    Apr 18, 2010
    Tennessee
    Something is wrong with the ABS system and needs fixed. You need to pull the code (s).
    You can check the ABS fuse for starters. When ever you get a ABS fault the ABS unit is disabled. You still have regular brakes where you make it to a shop.
    Scania man Thanks this.
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Volvo use frame mounted ABS units usually, so all sensor and actuator wires are on frame. I'm sure bad wiring
  5. v6killer
    v6killer Medium Load Member
    446
    122
    Dec 6, 2010
    ChicagoLand
    start here, and see if this helps you, it did for me.
    http://www.thetruckersreport.com/tr...olvo-forum/231711-abs-mid-136-sid-93-fmi.html
  6. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    No big deal driven my old 06 for years with that crap on
  7. Shashamane
    Shashamane Bobtail Member
    19
    6
    Feb 6, 2017
    Hi pabro, been looking for you all over the place.i need help with my truck
