Cheat sheet for oversize loads
Discussion in 'Flatbed Trucking Forum' started by mpd240, Oct 22, 2014.
  1. mpd240
    mpd240 Road Train Member
    1,540
    3,622
    Sep 17, 2011
    Minnesota
    Does anybody have a spreadsheet that list oversize requirements for each state. I've gone to MN SD and ND dot websites and am looking at their info. MN has a nice pamphlet that summarizes things. However the other two just have links to their regulations. I am looking for something for myself and the other drivers that I work with that outlines the individual state flagging lighting ect... Rules
  3. KenworthGuyNH
    KenworthGuyNH Road Train Member
    1,050
    2,686
    Dec 11, 2011
    Central, NH
    Sammons has a decent quick ref. book on their website you can download as a pdf. It's not gospel but a place to start.
  4. barroll
    barroll Road Train Member
    1,096
    544
    Nov 23, 2010
    Southwest Michigan
    Your permit ultimately dictates your lighting and flagging. That little yellow book isn't a bad place to look for suggestions as to stay a permit might fall in your lap with, though.
  5. mpd240
    1,540
    3,622
    Sep 17, 2011
    Minnesota
    I understand the permit has the requirements. However, I want to make sure I have the proper equipment and want to review the laws prior to getting the permit.
  6. KenworthGuyNH
    1,050
    2,686
    Dec 11, 2011
    Central, NH
    Here is the Sammons compilation.
    LostOne9, 281ric and MJ1657 Thank this.
  7. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,160
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    Carry enough flags to flag the load (4 corners unless over length too).
    Flags for the corners of the truck and trailer.
    Signs for truck and trailer, truck size not pilot car size.
    Strobe lights for both.
    Do that and you are covered pretty much anywhere for running daytime. As far as running times etc, the permit will dictate that, but it will become second nature after a short time.
    Martin
  8. xsetra
    xsetra Road Train Member
    5,094
    6,941
    Aug 21, 2011
    And flags on the widest part of load.
  9. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    as others said, the permit is the best place to look. states change their regs all the time, so any cheat sheet/bok may be out dated. Your permit should be up to date with current regs.
  10. macmanboomer
    macmanboomer Light Load Member
    72
    56
    Oct 19, 2014
    TN
    You could also find the provision sheets for the states that require them, you're gonna need them anyway. Most of the time they have that info on the provision sheet.
