Chattering front brakes
Discussion in 'Peterbilt Forum' started by Harley Tramp, Sep 12, 2014.
  1. Harley Tramp
    Harley Tramp Bobtail Member
    13
    Aug 28, 2013
    I installed new front brake shoes and drums on my 2006 Pete. I got a 20,000 pound axle. Bought all parts from Peterbilt. Brakes worked good for a couple of week, then they started to squeal which seems normal. Now sometimes they chatter. Its almost like the shoes are to hard. It does not do it all the time. Seems like right front is the worst. I took the drum back off twice and can't seem to find nothing wrong. HELP......
  3. xsetra
    xsetra Road Train Member
    5,209
    7,162
    Aug 21, 2011
    Do you have the correct springs on the shoes. If you used old springs they may be weak or stretched.
  4. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,334
    Nov 18, 2008
    CA...gold discovery foothills
    What are they chattering about?
    Must be female brakes if'n ya can't understand what they are saying!:biggrin_25524:
    Skwhirl, Dakota1358 and Scania man Thank this.
  5. RSQ20
    RSQ20 Medium Load Member
    Measure the drums for round..
    .... Philip
  6. Scania man
    Scania man Road Train Member
    2,199
    483
    Jul 1, 2011
    Saskatchewan
    Did you torque the wheel nuts when you put them back on ? not doing that with drum brakes can cause a slight warp on the drum that would give a judder or chatter when braking although you'd almost have it immediately after you fit the wheel, simple to fix....loosen the nuts and re-torque them, only takes a few minutes so worth a try
  7. Harley Tramp
    13
    Aug 28, 2013
    Thank you very much. I will pull the wheel and drum and install new spring. I will keep you posted. Good advice
