Changing the the ratio of rears
Discussion in 'Trucks [ Eighteen Wheelers ]' started by nb629, Oct 18, 2014.
  1. nb629
    nb629 Light Load Member
    213
    245
    Aug 21, 2012
    I am curious about what kind of job it is to change the gear ratio of the rear axles? I have found a truck that has all the specs I want except it has 4:10 rears and I would like to have a 3:70 or 3:55. Does this involve changing the rear axle ? Or can the gears be changed within the axle? It has 46k axles.Also would a high tourque transmission be a problem? Finaly what would the cost be to have a shop do this and would it be worth it? I am thinking of doing this for fuel savings. I work in Pa. mostly I-76, I-476, and I-78 area so there are plenty of hills. I always gross from 70k-80k and like to drive at 65 to 70mph. Will this change be worth it or should I leave it. I realy have my eye on this truck because I know the owner and all the history.
  3. Pool6710
    Pool6710 Medium Load Member
    662
    258
    Aug 10, 2014
    Minnesnowta
    What model # trans is in the truck? It could be a double over
  4. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    I would leave it the way it is for that kinda work your doing. the 46 rears are almost bullet proof and not very cheap to get parts for when you do need to. I will bet it would cost around $5000 to re-ratio them and that is if they don't find anything wrong with them when they are opened up.
  5. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Ask the owner how fast he ran and what he got for mileage .. It appears to be geared to run 55 .. Year make and engine may help others to give you advice Ratio swap is 2to4000 from I've heard as it sits now it's geared to pull at slower speeds before I did anything I'd run it a few trips at different speeds and go from there
  6. nb629
    213
    245
    Aug 21, 2012
    Thanks for all replies. It is a 2004 KW W900 with a 550 c15 and an 18 spd. I do not know the exact trans. model number. The owner just left for a three week vacation so I won't even try to get it. I am sure he has the proper trans for the Hp. He had this truck built this way and there has been know increase in Hp since the original build. He used this truck as a lowboy truck for his excavation company so 55 was probably as fast as he ever needed. I just want to run the speed limit at a more efficent rpm range. I will indeed run this truck the way it is for a while if I buy it.
  7. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    What size tires are on the truck now? If you've got lo pro 22.5's on there, buy used 24.5 rims and the next time you need tires get 11R24.5's. The effect on your RPM's going from LP22.5 to 11R24.5 is the same as changing 4.10 gears to 3.70...but you'll only be out the cost of the rims (which could be mostly recovered by selling your 22.5 rims) and the difference in price between the 11R24.5 tires and the LP22.5 tires you would have bought anyway. And if you aren't happy with the change, it is easy enough to swap back.
    For what it's worth, I've got 4.17 rears and 11R24.5 tires and can run 70-75 mph all day. Engines matter, though, because Macks like the 1400-1800 range, and 75 mph is at the upper end of that. If it has a Cat motor or one of the others that prefer the 1100-1500 range, you may be better off with the gearing swap unless you are going to pull really heavy loads or stay relatively local.
  8. Powder Joints
    7,506
    7,414
    Sep 25, 2007
    Rosamond, SoCal
    Changing ring and pinion is very uch a big deal, that truck is speced for Heavy Haul.
  9. nb629
    213
    245
    Aug 21, 2012
    With these specs and those speeds I bet your barely doing better then 4.5 mpg. My goal is to stay above 5mpg
  10. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,160
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    Depending on the trans model, if you sat at 65mph max, it will be fine. Will pull a hill like a raped ape!
    MPG wont be optimal, but you will get way over 5mpg with that setup, as the engine boost will be low most of the time.
    Martin
  11. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    That's a bet you'd lose. If your goal is to stay above 5, you'd be extremely pleased to run a truck with my truck's specs. While I've had more than a few tanks better than 6mpg, I have NEVER had one less than 5.
    leftlanetruckin Thanks this.
