Changing oil based on hours
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Cam Roberts, Jun 29, 2018.
  1. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    i have an older pete with cat. Local hauling triaxle dump in harsh conditions we change our oil in 10k mile intervals. I was thinking of changing my oil earlier do to circumstances. Last time I did an oil change was back in October. It was a slow winter. Past 3 months of working everyday and past few weeks 7 days a week 12-14 hour days, still only have 6 thousand miles on the oil change from last November. Truck just sits on high idle most of the time waiting. So it had me thinking, maybe the oil should be changed off of the hour meter. I would like to get as much of this motor as I can. Tell me your thoughts. Should I change the oil before 10k? How many hours? Or does idling, not have to be factored in
  3. AModelCat
    154,214
    I've always gone by hours for servicing trucks. Usually 250-500 hours depending on what the engine manufacturer recommended. I've never been around long haul trucks though. Just dump trucks, lowbeds, log trucks etc that spend more time running on low speed dirt roads than on highways.
  4. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    The more you idle the worse it gets. 250-300 hours is the low side, 400 is about normal, 600+ is high for hours.
    Oxbow, magoo68, Dave_in_AZ and 2 others Thank this.
  5. Cam Roberts
    1,621
    1,938
    May 13, 2018
    Thank you for this. So my theory is right then, I shouldn’t be going off miles in extreme conditions and long idle times right?
    Oxbow Thanks this.
  6. Cam Roberts
    1,621
    1,938
    May 13, 2018
    Thank you for this
  7. Cam Roberts
    1,621
    1,938
    May 13, 2018
    Sounds like so far 250 hours is where these conditions warrant a oil change in my case
    Oxbow and G13Tomcat Thank this.
  8. G13Tomcat
    G13Tomcat Road Train Member
    11,872
    42,142
    Jun 7, 2011
    In my old(ish)/(er) large car, pulling an asphalt tank; I always idle (the PTO of course) ... and I run no more than 300 hours. I don't play by mileage either.
    Oxbow and Dave_in_AZ Thank this.
  9. Cam Roberts
    1,621
    1,938
    May 13, 2018
    That’s great another confirmed 250-300 hour range. That looks to be a 359 . I own a 379.
  10. G13Tomcat
    11,872
    42,142
    Jun 7, 2011
    Yessir, you are correct. :) Hours always.....for me.
    Oxbow Thanks this.
  11. Heavyd
    7,749
    6,184
    Feb 4, 2009
    Yes, you should be going by hours. 250 hours would be a great starting point.
