changing ignition switch
Discussion in 'Freightliner Forum' started by angelor, Dec 11, 2014.
  1. angelor
    angelor Bobtail Member
    40
    May 22, 2013
    I have entire switch in my hand. Put paper clip in hole felt spring pop. Insert key and turn to left but tumbler does not come out. Any ideas before I drive off cliff?
  3. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    U have to usually turn to accessory position then pop the clip and u can pull tumbler out unless it's in accessory it doesn't come out
  4. angelor
    40
    May 22, 2013
    The spring inside had come apart and was not letting it release! Cut it open.
  5. Bigman58
    Bigman58 Light Load Member
    60
    11
    Feb 12, 2014
    I just let a mechanic pop mine out! I took out the old and walked it over to him with the new, and let him do it. They are a real pain in the ### as you are experiencing.
  6. Bigman58
    60
    11
    Feb 12, 2014
    I also gave him a couple of bucks. :)
  7. CarhaulerEd
    CarhaulerEd Bobtail Member
    7
    Mar 1, 2017
    How about if you lost your key is there a way to remove it without the right key to turn it..
  8. CarhaulerEd
    7
    Mar 1, 2017
    Need help I lost my key and need to remove ignition key tumbler on a 09 Freightliner Cascadia.
  9. Animosus
    Animosus Heavy Load Member
    709
    2,781
    Dec 7, 2015
    SE Wyoming
    A dealer can look up your key code with the last 6 of your vin. Any decent locksmith will be able to make you a key for about $10 with this key code. That's how we do it here.
    QUALITYTRUCK Thanks this.
  10. CarhaulerEd
    7
    Mar 1, 2017
    Yes I tried this but eventually the key didn't work because the locks were probably switched out before.So I purchased a new set of door locks and ignition key tumbler but was wondering how to remove the tumbler without having the actual key ...Thanks for the info...
  11. tallmon
    tallmon Medium Load Member
    657
    319
    Oct 22, 2014
    How do you replace the tumblers in the door?
