changing head gasket on paccar mx13 epa 10... help!!!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by splittero1, Feb 25, 2020.
  1. splittero1
    splittero1 Bobtail Member
    29
    9
    Sep 4, 2018
    ok guys.. I am leaking water from the head gasket on driver side. about in the middle of engine. also now is leaking on passenger side .. passenger might be exhaust manifold leak but I think head gasket..
    so I am not a certified mechanic of any kind.. I can change parts and turn a wrench. ive changed head gaskets on gas car engines but never anything like a diesel. I have been told its a job that lists for just over 20 hrs of labor.. so more than $2500. easy depending on the shop rates. ive got maybe just enough money to buy parts.. so.. ok everyone please sit down... im gonna try to do this job myself... ive been looking and trying to learn from you tube vids.. but cant find much on paccar.im gonna need steps, for tear down, what to look for what to watch out for.. do's and dont's.. ( please don't tell me to take it to a shop unless ur willing to pay the labor for me ) lol short cuts that you knw about.. to save money and time.. such as is it possible to remove the head without removing the exhaust manifold? one less gasket I have to buy right? so short cuts you know ? also for putting this thing back together.. tips? tricks? torque specs? sequences ? and then last but not least please pray for me that I get it right the first time... I gotta get this done in a week if possible. please help me out if you can .. umm on a side note.. ive noticed that my oil pressure goes up pretty high when I accelerate.. at least until the truck gets really good and warmed up.. didn't do that before the leaking.. anyone have any ideas why?
    truckdriver31 Thanks this.
  3. Chubby Fly
    Chubby Fly Medium Load Member
    569
    796
    Nov 25, 2019
    if you are can work on a car like that, it should be eaiser for you doing the truck. years ago I was in same boat as you when i bought my truck. Not a paccar but a cat. I just took it all apart which was easier becuase you have much more space in a truck to work. Plus everythinmg is much bigger parts wise which made it much easier. I do all the work. Torque specs are all the same with bolt size and bolt grade. but you have to check everything out and make sure your head isnt warped. I have found that it usually isnt just a head gasket, its usually more to it than that but good luck
  4. AModelCat
    154,260
    Tools. You better have a big 3/4" drive torque wrench and a big breaker bar. Then the specialty measuring tools like feeler gauges, dial indicator, sled gauge, quality straight edge etc.
    I'm a mechanic by trade. I decided to rebuild an ancient 3406 Cat and I'll tell you, I had to invest close to $1,000 in tools I didn't have (normally the shop supplies all the stuff above and beyond your standard hand tools).
    Biggest thing is cleanliness. Wash that engine and the areas above and around it clean enough to eat off, then wash it again. Dirt is very bad. Have a nice, clean bench set up, lay out all your parts on the bench as you go. Mark and label EVERYTHING! Make absolute sure everything goes back into its original place. Don't go mixing lifters, rockers, pushrods etc around. #1 intake goes back to #1 intake etc. Lint-free shop towels work good to wipe out the cylinders of any spilled oil/coolant.
    Normally when I do heads/headgaskets, after I'm done I fire it up and let it run 5-10 minutes, then shut it off and dump the oil and replace filter. You will usually get some coolant down into the pan once the head comes off.
    rachi, Dave_in_AZ, SAR and 3 others Thank this.
  5. splittero1
    29
    9
    Sep 4, 2018
    as far as tools go I know a mechanic that says he will kinda guide me as I go.. he is busy doing trans rebuilds and stuff. but im sure I ight be able to borrow torque wrenchs and stuff. and cleaniliness yeah I don't want any dirt on anything. so yup I will make sure I have clean work space. don't know abt labeling yet but I do plan on putting everything in order as I take it off. so it will go back in the same order going on. good tip abt replacing oil. trucks due for oil change anyways. so im thinking my first step would be to allow some antifreeze to drain out of engine.. not sure how much I need to remove though. then I guess removing outside engine components that will be in the way. wheeew the more I think of this job the scarier it gets for me.. ohh as far as engine block warpage and head warpage.. this is pretty much a new head.. it was put on last summer.. not even a year old yet.. I think the techs that did the job didn't do it right or something.. my mechanic friend says sometimes it happens that you get a cold water leak after a job like that, but the techs said at the time that liners were good and block was good.. ill have my mechanic friend take a look if he has time .. but he is very busy.. so we'll see..
    ok so drain antifreeze remove outside components.. .. next?
  6. AModelCat
    154,260
    Unfortunately I don't touch on-road stuff anymore so I can't give you any specifics. More just general advice since I've literally only seen 1 MX engine and I was about 30 feet away.
    Take your time. When you rush, you screw up. I would not assume the head is ok and just reuse it. Definitely want to give the bottom surface a good cleaning and check for warpage with a feeler gauge and straight edge (block and head). I don't know if the MX has a liner protrusion spec but if it does I'd make dang sure they're in spec or you'll be opening up that engine again in the near future.
    Camera phone/tablet is handy as hell too. Take lots of pictures so you can reference them later if you need to.
  7. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    !st buy a used MX repair book or the down loaded type from any of the on/line sales places then you will have all the info you need to work on your truck?
  8. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    How will you lift the head?
    Remember it is a 1 piece head.
    As to a manual...........might want to ask these guys nicely if they will help you.
    @pushbroom
    @spsauerland
    spsauerland and splittero1 Thank this.
  9. splittero1
    29
    9
    Sep 4, 2018
    I will probly use a cherry picker or something like that.. my friend just had his done in his shop a little while ago.. he borrowed a larger size cherry picker from someone.. hoping I can borrow it too.. yup I think those two guys already commented on my thred here so I will ask questions when I can .. thnks
  10. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Here is the technical data, your BPV may be different. Paccar (DAF) is very picky on cleaning cylinder deck. They want no power tools. Just plastic scraper and brass wire brush. The surface is the proper roughness for the MLS head gasket, they don't want it any rougher or smoother. MLS head gasket are less forgiving on surface finish vs a graphite constructed head gasket. The block and head are made of CGI, so not very many machine shops can resurface them. They don't even have a check for flatness on the cylinder head. I seen one where it was checked and found to have an arch to it @ a Cat machine shop. Paccar said this is by design (I don't get it), but they recommended a new head. If the machine marks (striations) appear to be inconsistent, I would recommend a new head. Maybe last gut got crazy with a roloc disc.
  11. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    If this is your first go at a large diesel, Paccar is not exactly mechanic friendly. Cat and cummins seem alot more logical as to what to remove next/ how would I remove this. Paccar is sometimes a multi step process just to remove one item. I think you might want to re-think doing it yourself or at least having someone who has done one before help you.
    As to the actual failure, I know you think its just a simple head gasket or poor workmanship but I disagree.
    I don't like to throw other shops under the bus until you can have full proof of what happened. Innocent til proven guilty. I have been thrown under the bus before and it sucks. Didn't even get an apology when I proved we had done nothing wrong and it was an unrelated failure. Everyone seems so quick to #### on mechanics these days.
    The only time I have ever had a water leak from a Paccar headgasket has been warped block/head or eroded deck surface. As @spsauerland stated, MLS head-gaskets are not very forgiving for damaged block sealing surfaces. If you ran with a blown headgasket for a long period of time I have seen the escaping gasses damage block surface to the point of not being able to sufficiently seal off coolant.
