Changing gear lube in 13 speed tranny
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ozzy_27, Dec 9, 2020.
  1. ozzy_27
    ozzy_27 Bobtail Member
    Dec 9, 2020
    Anyone know recommended oil to use in Eaton fuller 13 speed. Truck is used year around in north Dakota sits outside all winter. I know synthetic oil but what weight 50w or 90w gear lube.
  3. MRMTRANS
    MRMTRANS Medium Load Member
    334
    372
    Apr 28, 2015
    I am pretty sure either weights can be used. I know 50w was put in my RTLO16713A when it was installed, swapping out a Meritor 10 speed.
  4. AModelCat
    154,278
    50W synthetic I believe is typically used. I was told never use gear oil as it affects the synchro?
    Either way, Eaton publishes pretty much everything you need to know about their transmissions and axles on their website for free access. Wouldn't hurt to burn over there and download the manual.
  5. MRMTRANS
    334
    372
    Apr 28, 2015
    Link Sharing
    I hope this link sharing works. If so, go to page 10. Looks like either weight is fine. I'd use SAE 50 for fuel mileage.
  6. MRMTRANS
    334
    372
    Apr 28, 2015
    You need to tap on Link Sharing. I would have thought the address would just appear. I've never tried sharing a link on my phone.
  7. ozzy_27
    Dec 9, 2020
    Thanks I'll try and find 50w synthetic oil and not 50w synthetic gear lube!
    Goodysnap Thanks this.
  8. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    You may not find 50 wt at local dealers. Some time ago the fluid spec changed to 40 wt synthetic trans lube. This 40 wt is backward capatable for all Eaton manual and automated transmissions.
    A5¢, spsauerland, pup and 2 others Thank this.
