Change door lock barrel
Discussion in 'Kenworth Forum' started by Ozdriver, Apr 20, 2017.
  1. Ozdriver
    Ozdriver Heavy Load Member
    767
    1,390
    Oct 16, 2015
    Australia
    Iv'e got a K100. When you put the key into the passenger door lock, it turns right around and nothing happens, in other words it's broken. I've bought the key and barrel kit off KW, 2 door barrels and the ignition switch barrel with 2 keys. I've changed them in the past, problem is I've forgotten how to change the door lock barrels.
    I remember you cut off the stainless cover over the lock, problem is I've forgotten where you go from there. You don't have to touch the interior trim.
    Couldn't find anything on google, and on TTS one guy removed part of the interior trim and I know you don't have to do that.
    Anyone know where I can find step by step instructions, preferably illustrated? Or can anyone explain it step by step?
  3. noluck
    noluck Road Train Member
    1,616
    11,683
    Jun 10, 2011
    greenville,sc
    I always pulled the door panel, I don't know for sure on a k100, but all the ones I changed have a retaining clip on the back side. Pop it off and pull the rod loose and it should come out of the front.
    Diesel Dave, mslashbar and Ozdriver Thank this.
  4. Ozdriver
    767
    1,390
    Oct 16, 2015
    Australia
    I'll be looking at it tomorrow, but I know you can do it all from the outside because I've done it before. After you chisel the stainless cover off you somehow put a small blade down the side of the barrel and pull it out, but it escapes me how I did it exactly.
    noluck Thanks this.
  5. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    You just wanting to change the tumbler barrel or the whole thing?
    Ozdriver Thanks this.
  6. Ozdriver
    767
    1,390
    Oct 16, 2015
    Australia
    Just the tumbler barrel.
  7. Superhauler
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    There is a certain position to turn it and it will pull right out. But I think you have to disconnect the lock linkage to do it.
  8. OLDSKOOLERnWV
    17,806
    268,402
    I need to do the same thing on my 900, just put off buying a new one. Driver side barrel missing all together.
  9. bigguns
    bigguns Road Train Member
    2,846
    6,853
    Jun 13, 2013
    Omega,GA
    Doesn't it just SUCK when you have done something and can't remember how you did it? I have that happen a lot lately.
    Mr Ed, Ozdriver, Diesel Dave and 3 others Thank this.
  10. clausland
    clausland Road Train Member
    1,933
    11,067
    Dec 5, 2014
    North Woods
    I had the same problem with Pete, tried everything, took it to a locksmith, he had the tools to swap it out quickly, charged me $10...
    OLDSKOOLERnWV and Ozdriver Thank this.
  11. OLDSKOOLERnWV
    17,806
    268,402
    Well... my lock is missing on the drivers side, and since it needs to be installed I bought a new set (2) in a pack. By turning the barrel all the way to the left it pulls out slick as a hounds tooth. Won't be able to with it installed in IMG_7810.JPG the door, not that I can see. Mine is a 1995 W900L.
