Chalmers suspension truck sways on freeway?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mixingconcrete, Jun 7, 2020.
  1. mixingconcrete
    mixingconcrete Light Load Member
    99
    40
    Apr 14, 2019
    Hello, we have a couple mixer trucks with the chalmers suspensions and some of them sway a little when going 40mph+. It is not super horrible but annoying having to always correct it. Anybody experience this and know how to fix this problem?
  3. PE_T
    PE_T Road Train Member
    Check your shocks and torque rods for loose bolts or worn bushings. You may have to take out your shocks to check that they still work. Leaky shocks is also bad.
    650cat425 Thanks this.
  4. AModelCat
    154,481
    Chalmers is a pretty stout suspension. It shouldn't be swaying unless there are some worn out bushings.
    I'd check the tire pressures too. Low tires are going to make it sway some.
    650cat425 and PE_T Thank this.
  5. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    What makes you think its the rear suspension causing your complaint? Is the front end light when loaded? Any chance its the steer thats wandering and you overcorrecting to compensate? Does it do it empty?
  6. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    They make different restrictor cans that sit on top of rubber spring block. I know some are referred to as high stability.
    BoxCarKidd, PE_T and Goodysnap Thank this.
  7. spsauerland
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Also, plate that bolts to top of beam bolts tend to loosen up and tube welded in center of plate tends to rot off. Cans and plates aren't very expensive. Give each torque rod and pull and push. Any play should be addressed. Replacing bushings are pretty straightforward. I recommend new hardware when replacing bushings. OEM ones come pre-applied with threadlocker. We also found good practice to torque the flange locknuts. Impact only was resulting in loosing spigot caps.
    PE_T, BoxCarKidd and Goodysnap Thank this.
  8. mixingconcrete
    99
    40
    Apr 14, 2019
    Well i dont think it is the front because on one of the trucks we replaced almost all the suspension components and it still wonders on the road. The rear everything seems tight when we move by hand but im thinking maybe the weight of the truck keeps everything under tension and it might be hard to spot the problem. It does it worse when loader but when its empty it also does it a little. Another thing that sucks about replacing parts on these suspensions is that the concrete drum is right about the axles and suspension so the torque rods over the axles are a pain to replace. We got 15 trucks with the chalmers so dont really want to just start throwing parts at them unless we find out what exactly is causing the swaying to happen
  9. mixingconcrete
    99
    40
    Apr 14, 2019
    We even replaced the bushings on one of the trucks and i couldnt believe that it didnt even slove the problem. We will check out the plates on top of the beam and see if they have any play.
  10. Roberts450
    Roberts450 Road Train Member
    2,237
    3,635
    Feb 6, 2016
    I know you said its worse when loaded then it is empty but just for shizz and giggles have you tried stopping the drum for a minute or two to see if the sway stops?? Could be rollers on the drum causing the sway and not the suspension.
    FinkPloyd Thanks this.
  11. REO6205
    REO6205 Road Train Member
    13,172
    60,483
    Feb 15, 2014
    California.
    It could also be the slump. I noticed that a mixer will handle differently with a thicker mix on board. The mix runs farther up the inside of the drum while its turning. With a low slump try running your drum a little slower.
