Chains and binders
Discussion in 'Flatbed Trucking Forum' started by rich1833, Nov 3, 2012.
  1. rich1833
    rich1833 Bobtail Member
    21
    I'm looking for a place to store my chains and binders without adding a headache rack. Anyone have any ideas? Im thinking maybe something like this mounted under the trailer. [​IMG][​IMG]
  3. Mommas_money_maker
    Mommas_money_maker Road Train Member
    1,122
    765
    Oct 2, 2011
    North Carolina
    A box would be a huge PITA to keep them sorted out and being able to use. A hanging rack is the only way to go.
  4. fortycalglock
    fortycalglock Road Train Member
    6,150
    6,581
    Jun 25, 2011
    Tourist Town, FL
    Keen trucking uses a top opening box for chains and binders. You might try calling the Carlisle shop to see if they'll sell you one.
  5. Diesel Dave
    8,520
    23,418
    Jan 20, 2010
    Hesperia, Ca.
    I use a Merrit box that fits between frame rails on the tractor and works as a cat walk as well. It fits 12 chains and binders.
    whoopNride and SHC Thank this.
  6. Noggin
    Noggin Road Train Member
    2,494
    977
    Apr 10, 2011
    Houston, TX
    Is that your trailer with the rack on the bulkhead? What is wrong with that? I'd use that over a side box anyday, plus, they are already on your trailer. Easier to lay out and put away, imo
  7. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    A side box is great for binders (I have all of mine in my 18x24x24 step-box)
    As for the chain rack, mounting it UNDER the trailer as you said would be a HUGE mistake. The chains will rust and you will easily loose them, and binders would last maybe a week in that spot as well.
    Just wondering, why do you not want a headache rack??? I know a lot of guys with the big streched out trucks don't run them and most have rear windows, but I'd prefer the convience of the enclosed rack and the extra safety it provides just incase some yahoo pulls out in front of you and you have to slam the brakes.
  8. rich1833
    21
    No that not my trailer its a stock photo of the chain hanger. Im wanting to install that hanger inside the box and hang it under the cab not under the trailer. All the trailers Im pulling have bulkheads on them. Since we change trailers out all the time Im looking for something else.
  9. Logan76
    Logan76 Crusty In Training
    4,528
    17,698
    Jul 12, 2009
    kittanning, PA
    I think everyone missed the point that you wanted that chain hanger inside of your tool box!
    You could just buy a plain jane tool box and have someone weld a piece of angle iron inside of it to hook your chains and binders to.
    Mommas_money_maker and SHC Thank this.
  10. Noggin
    2,494
    977
    Apr 10, 2011
    Houston, TX
    I did miss that. so yuo are wanting to put it down around by where the tarp box usually goes? As long as the box has a good rubber seal and water doesnt get in easily to rust the chains, I can see that working...
  11. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    Don't forget you can drill a drain hole in each corner of a box.
    SHC Thanks this.
