Chain Binders
Discussion in 'Flatbed Trucking Forum' started by Bay, Dec 7, 2015.
  1. Bay
    Bay Bobtail Member
    15
    Dec 3, 2015
    Can someone give me more details on differences between lever and ratchet chain binders? What are the benefits of each, the differences? How to stay safe with each? Is there a big price difference?
    Thanks!
  3. 201
    201 Road Train Member
    12,047
    24,590
    Apr 16, 2014
    high plains colorado
    Hi Bay, well, ratcheting binders are a lot easier, as your load shifts, a simple few cranks of the ratchet binder, and you are good to go. A lever binder, you have to undo the binder, grab a new link, and pull it down again. I can't believe lever binders are still legal. Also, here's a little tip, when chaining something down, make sure all the links of the chain line up ( chain not twisted) and the chain will not loosen. I'd go with the ratchet binder. Be careful.
    burnsey, Hurst, peterbilt_2005 and 2 others Thank this.
  4. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
    Yup the old ones can get you killed
    Sneakerfix and 201 Thank this.
  5. 201
    12,047
    24,590
    Apr 16, 2014
    Years ago, you could always tell who pulled a flatbed. No front teeth.
  6. TripleSix
    127,950
    As usual, there aren't any hard, fast rules in securement. I myself prefer ratchet binders in most my chain securement, BUT there are certain loads where ratchet binders are better. Certain loads do not give you the room to swing the handle to tighten ratchet binders. Snap binders will do the trick. So I would recommend carrying both instead of just one type of securement.
  7. Mattflat362
    Mattflat362 Road Train Member
    2,696
    5,723
    Feb 18, 2015
    Avon Lake, Ohio
    I recently splurged on some ratchet binders and love em! Only way to go!
    mountaingote Thanks this.
  8. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    Just be sure to get the new style of snap binder. Or you might be looking like you done prison time as someone's girlfriend real quick.
  9. Ruthless
    Ruthless Road Train Member
    8,798
    86,132
    Aug 28, 2010
    The City.
    I have both. I prefer snap binders. I don't chain nor haul anything real big or heavy.
    Never busted teeth out yet (nor come close) nor had any other problems.
    Bigger n heavier stuff ratchet binders are better in my experience.
    Diesel Dave, Al. Roper and MJ1657 Thank this.
  10. MJ1657
    MJ1657 Road Train Member
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    Diesel Dave and Al. Roper Thank this.
  11. 201
    12,047
    24,590
    Apr 16, 2014
    I believe, years ago, flatbed loads ,like tractors and machinery, didn't have "D" rings or load fixing points, and that's where the problems came in. I heard, cheater bars on lever binders were illegal. Is that true?
