Century/ Columbia door panel question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Freightlinerbob, Jul 21, 2012.
  1. Freightlinerbob
    Freightlinerbob Road Train Member
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    I ran new coax through my driver side door and could not figure out how to remove the interior door panel. I worked around it, but I'm having a he'll of a time getting it back together now. Is the window crank assembly mounted to the interior panel? The window is really hard to crank now and I can't get the panel to sit closer to the door. Anybody have experience with this?
  3. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,160
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    My 06 Columbia has electric windows, so may be different.
    There is a line of bolts around the outside edge of the panel that need removed.
    The hidden bolts is the mirror one though. You need to remove one of the bolts that hold the exterior mirror onto the door to be able to remove the panel.
    IIRC there are also 2 Torx bolts that need to come out once the panel is loose. They fasten the window track to the panel.
    Over engineered, especially for a Freightliner!
    Martin
  4. Freightlinerbob
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    OK, yes I had all the screws out but could not get the panel off. Where are these 2 Torx screws that I've obviously missed?
    Thanks.
  5. tallmon
    tallmon Medium Load Member
    657
    319
    Oct 22, 2014
    Where are those Torx screws? I need to take mine apart this weekend since the exterior door handle/lock is loose.
  6. Slowpoke KW
    Slowpoke KW Road Train Member
    1,170
    12,822
    Dec 7, 2015
    OK
    You should be able to tighten that without removing the entire door panel, just pull the back panel out of the door pocket
    At least that's the way I used to do it
    tallmon Thanks this.
  7. tallmon
    657
    319
    Oct 22, 2014
    22 degrees and snowing.
    I pulled the pocket liner out but couldn't get to the nut holding the mechanism. There are about 30 screws hold the whole panel in place, some covered by plastic covers. Too cold, will do when it warms up.
    Instead, I took a piece of thin plastic and shimmed it, between the casing and the sheet metal. It'll hold until summer. ;)
  8. Slowpoke KW
    1,170
    12,822
    Dec 7, 2015
    OK
    Don't blame you given that temperature I would do the same thing
    Don't know about on the Columbia but on the Century Class there was one bolt on the outside that was hidden under the mirror mount cover
  9. Zandersn
    Zandersn Bobtail Member
    Did you resolve the window issue? I ran New coax yesterday and now I can't roll my window down. Not sure what the problem is. Can anyone help?
  10. Zandersn
