Cell Phone Log Book Apps
Discussion in 'Questions From New Drivers' started by SippingDiesel, Jan 28, 2014.
  1. SippingDiesel
    SippingDiesel Light Load Member
    50
    7
    Jan 17, 2014
    Morehead city, nc
    Does anyone use these apps to help keep track of their day for back up purposes or are they a waist of time?
  3. x#1
    x#1 Road Train Member
    1,773
    1,104
    Dec 24, 2009
    Cherokee County, Alabama
    use loose leaf logs and a composition book.no need to keep an electronic trail to that degree as there is enough w/fuel receipts and toll booths,etc.besides,if you are a company driver w/qualcom or whatever and elogs,every minute of your day spent in that truck is already kept up with and on permanent record.
    SippingDiesel Thanks this.
  4. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    I use BigRoad app (free) keeps me straight on 30 min. break and 34 hr restart. I'm working on the safety dept. trying to let me e-mail them in, instead of copying into paper book. I think I've just about got them to see my point. The only charge is if the company "enrolls" the network to keep track of all the trucks and their whereabouts.
    HDFEDTRUCKER2010 Thanks this.
  5. SippingDiesel
    50
    7
    Jan 17, 2014
    Morehead city, nc
    So basically the qualcom system maps out your day and tells you when your break is coming and counts down your drive hours and work day hrs. Is it idiot proof and do you still have to paper log just in case/
  6. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    No. If you have an eLog unit (and you will) no need to be redundant and waste time with something else. The carrier doesn't want you doing this, and if the eLog unit takes a dump (they rarely do), it'll be the carrier's problem, not yours.
  7. Krashdragon
    Krashdragon Medium Load Member
    651
    305
    Apr 10, 2012
    Cleburne, Tx
    You need to have paper logs available if the QC breaks. But don't try to keep both an electronic and a paper copy, that would be 2 sets of logs. The paper is in 15 min intervals, and the electronic to the minute, so no way can they be identical. The QC counts down your hours, it's up to you when you take your breaks, etc.
    There is an app called Recap + that I like. You can track your 70 and it calculates your recap hours. so you can plan your 34 resets if you need to.
    mary
    teqntexas and SippingDiesel Thank this.
  8. SippingDiesel
    50
    7
    Jan 17, 2014
    Morehead city, nc
    So if the QC goes down you would start the paper log from there on?
    You use the app as a tool to help predict your day and where you might be at?
  9. teqntexas
    teqntexas Medium Load Member
    689
    547
    Jan 25, 2012
    Ft. Worth Tx.
    keep it simple. if your on elogs, keep some blank paper ones incase your elog goes down. recap + is nice if you want some help figuring out resets. wouldn't keep both phone app/paper logs side by side because some dot may not like you keeping two separate log books. plus it's extra work and heh, i can find other ways to spend my time on the road. like, umm. sleeping.
    just my two cents.
  10. Moosetek13
    Moosetek13 Road Train Member
    14,520
    17,975
    Nov 1, 2010
    Burnsville, MN
    NO!
    If your e-log goes down it is your responsibility to have paper log sheets available to fall back on.
    It comes back to the drivers responsibility - NOT the carrier's.
  11. Moosetek13
    14,520
    17,975
    Nov 1, 2010
    Burnsville, MN
    Is it really so difficult that you need an app to help you?
    It is very basic arithmetic.
