Hey,
I'm interested in driving some sort of truck or specialized vehicle for a construction company. im wondering what level of cdl qualification i need for say a dumptruck or something along those lines. i havent been able to find any clear conscice guidleines as to which grade of cdl( a b or whatever else) allows you to drive which type of vehicle. any help clearing up what qualification allows you to do what would be greatly appreciated.
Thanks and sorry if my post was slightly disorganized or worded poorly. for some reason im having one of those days were the english language and grammar itself escapes me.
Tyler
CDL qualification to drive construction vehicles?
Discussion in 'Questions From New Drivers' started by thewisepapaya, Nov 5, 2007.
Standard rules apply, whether or not it is used in construction or other forms of transportation. If it is a straight truck, like a dump, then a class B license, with air brake endorsement is going to be needed. If it is a combination vehicle, typically a tractor and trailer, then you need class A and air brakes. Simplest thing to do is get Class A, airbrakes, and tanker endorsements and that should cover 99% of construction situations. Unless you find a need for it, you won't need hazmat for that work. If you do need it, your employer will inform you of the need for it.
If he works for a company that has a fuel and lube truck he'll need haz-mat for that, unless he wants no part of that particular job.
Here in MN you would need to get a class A if you drove a dump truck, and ever towed a trailer. You know, skid steer, loader etc., only having your B would mean you were illegal. Take the advice, just get the A and be safe! Good luck!
You may also want to view the FAQ segment on the teamsters website relating to construction division.
I know a lot of contracts require a full on CDL regardless of equipment utilized. (versatility etc etc)
A lot of the non union construction companies that work small contract to small contract may not require as much but the work is not as steady and from what my buddy Ray says (dump truck - 3 axle non air brakes / backhoe) the pay tops out at about 15$ an hour.
most sizeable dumpers have air brakes and gross weights above 34K - so a class A would be required.
my rule of thumb is get the highest level of license you can and then filter down to the job you want... (I have every endorsement known to man - I think I am even legal for the space shuttle hehehheheheh)
