CDL permit test
Discussion in 'Questions From New Drivers' started by Kobe1225, Feb 11, 2022.
  1. Kobe1225
    Kobe1225 Bobtail Member
    32
    33
    Apr 18, 2021
    What is the best way to study for the CDL permit test? All answers are helpful
    Chinatown, BennysPennys and Boondock Thank this.
  3. TROOPER to TRUCKER
    TROOPER to TRUCKER Anything Is Possible
    7,652
    12,685
    Dec 15, 2014
    Charlotte, NC
    Top right drop down box here has practice tests
    Coffey, BennysPennys and Boondock Thank this.
  4. tscottme
    tscottme Road Train Member
    Like @TROOPER to TRUCKER said this website has online practice tests or click on this link. You will need to pass the tests for General, Combination, and Air Brakes. There are multiple version of each of those tests.
    I prefer to take the practice tests at another website called TruckerCountry.com. In my experience Trucker Country has more versions of each test so it's less likely you will see a surprise question when you take the test at your state's testing center. Just keep taking the online tests until you regularly score 90% or more.
    The technique I suggest is to take the tests at TruckerCountry.com. Take the test in Classic Mode. Don't answer any questions, but scroll to the bottom of the page and click Calculate Your Grade. This will give you the correct answers to each question. Now take the same test again, but mark the correct answers for each question. After each correct answer is marked. Retake the same test BUT ONLY READ THE CORRECT ANSWER. Never read a wrong answer for the questions. Do this for each version of the test and do it for each version of the General, Combination, and Air Brake tests. On test day all you need to do is read the question at the state testing center and recognize which answer is familiar.
    Good Luck.
  5. MOBee
    MOBee Road Train Member
    1,774
    10,159
    Apr 27, 2014
    Do you all have a good video of them pretrip inspection that shows the part in question? If my student doesn't know what it looks like she/he can't confidently touch a part and then verbalize what they would do then.
    tscottme and Boondock Thank this.
  6. Boondock
    Boondock Road Train Member
    1,198
    10,071
    Jul 20, 2019
    Also it helps to read your states cdl handbook.
    newnew, Kinsman, BennysPennys and 2 others Thank this.
  7. tscottme
    There are numerous pre-trip inspection videos on YouTube. I suggest you use the ones from truck driving schools.I like this one
    MOBee and Boondock Thank this.
  8. dave01282000
    dave01282000 Medium Load Member
    353
    742
    Jun 16, 2021
    At the same time you can test for the tank and double/triple endorsements - both just a one time written test and not difficult.
    HAZMAT requires a few additional hoops with TSA background and fingerprints and also needs to be renewed periodically. Some companies will pay for you to get that one later if they require it.
  9. Chinatown
    Chinatown Road Train Member
    73,281
    164,683
    Aug 28, 2011
    Henderson, NV & Orient
    Scroll to top of this page and click on the 3 horizontal lines.
    Boondock Thanks this.
  10. tscottme
    Agree strongly with the above. IMO, everyone should get the Tanker endorsement, along with Doubles/Triples. Every endorsement is one more obstacle you REMOVE from your future career. The tests are simple and cheap and never expire or require re-testing.
