CDL driver training and truck rental in GA without using a school (individual)?
Discussion in 'Questions From New Drivers' started by kgreatdivide, Nov 5, 2013.
  1. kgreatdivide
    kgreatdivide Bobtail Member
    Hi,
    I am investigating the possibility of finding individual training and truck rental for the CDL driving test. Wondering if there are any options out there that would be cheaper than school?
    My plan is not long hauls but the purchase of a vacuum truck for a business startup.
    Thanks for any replies.
    Keith
  3. 123456
    123456 Road Train Member
    10,555
    5,747
    Oct 22, 2010
    32179
    There are individuals/small outfits that advertise this service.
    Have you checked around ?
  4. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    What size GVWR truck do you plan on buying? Manual or Automatic?
    If it's under 26,000 lbs GVWR you don't need a CDL. Is there a trailer in the mix?
  5. kgreatdivide
    Over 26,000. No trailer. Either transmission, depending on best deal I can find on a truck. Thinking ex-municipal sewer jetter / combination truck for hydro-excavation business.
    Thanks
  6. CondoCruiser
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Here's an old one that's going up for auction might be cheap to start out with.
    http://www.truckpaper.com/list/list.aspx?bcatid=27&catid=239
    The only real training you need is learning to double clutch and the DOT regulations. If you stay within a 100 miles you'll be classified as a short haul driver and be exempt from many regulations.
    Is there any reason why you can't test in the vehicle you purchase? Just have a CDL driver with you? You really don't need to fork out a few grand for school in this situation. You can get by with a Class B CDL.
    You'll also need a DOT physical and medical card. They are usually cheapest at walk-in clinics. Google "(your town,state) DOT physical" to find the ones closest to you. $40 is the cheap end. You have to make sure the state DMV gets a copy of the medical certificate which they will require testing day.
    Here's a link to the regulations you'll need to learn. Pay close attention to 382, 383, 387, 390, 392, 393, 395 and 396. There's no testing on them but you get rewarded with fines for not knowing them. :)
    http://www.fmcsa.dot.gov/rules-regulations/administration/fmcsr/fmcsrguide.aspx?section_type=A
    Ga Dawg141 and 123456 Thank this.
