CDL CLASS B TESTING
Discussion in 'Questions From New Drivers' started by LAGP93, Jun 28, 2017.
  1. LAGP93
    LAGP93 Bobtail Member
    8
    Phoenix
    Hello I want to get my cdl class b license, I already have my permit for class b. I am planning to drive a manual transmission dump truck. When I get my license.
    I currently live in Phoenix AZ, and I am not able to find a place that will rent me a dump truck to take my test. I haved email Ryder company to rent a Straight truck, and they said they do not rent for cdl testing purposes.
    will a tractor by itself work for testing?
    The School I will be testing at, only has a automatic straight truck and I will have a restriction on my license if I past.
    Which other vehicle can I use to test for cdl class b license. Can I use a Tractor bobtail to test in? Like the one in the picture?
    Thank You.
  3. Moose1958
    Moose1958 Road Train Member
    15,090
    33,172
    Dec 17, 2010
    Williesburg, Virignia
    A Road Tractor without a trailer is a Class B vehicle. I do not know if an examiner giving the road test will accept it.
  4. Allow Me.
    10,642
    12,101
    May 28, 2009
    Rancho Mirage, Ca.
    I think you can but call DMV and ask them........
  5. LAGP93
    8
    Phoenix
    Thank You for your reply.
    If I am not able to in the Tractor, which other vehicle will work for testing for class b license.?
    Thank You.
  6. Moose1958
    15,090
    33,172
    Dec 17, 2010
    Don't over think this. Class B vehicles is any straight vehicle with a weight rating over 26,001 Pounds. Get a copy of your states Commercial Drivers manual. There should be examples of such vehicles in it.
    Good luck with the testing!
  7. LAGP93
    8
    Phoenix
  8. Ridgeline
    22,103
    113,210
    They should accept it, I've tested with one before. It is a legal class B vehicle as long as it has no trailer that has the GVW over 10k on it.
    HOWEVER do not drive it there alone, if you have a permit, then driving with a class B or A driver is required and the examiner may not even give you a road test because of it.
  9. LAGP93
    8
    Phoenix
    Will I be able to test with no trailer hook on to it? Just the tractor by itself?
    Thank You for your help Ridgeline.
  10. Moose1958
    15,090
    33,172
    Dec 17, 2010
    Be careful with this. A vehicle over 10,001 and under 26,001 is only defined as a CMV, you DO NOT NEED A CDL to operate it. Once you get above the 26,001 weight rating then the CDL law comes into play. I have seen examiners decline to CDL test in vehicles under that 26,001 weight rating. Last time was in Georgia. I highly advise ANYONE doing CDL testing to do so in the proper class and weight rating.
  11. LAGP93
    8
    Phoenix
    Okay thanks for your help Moose1958, I think I will just have to go to the office were I will be testing and ask them if I can test in it, with no trailer hook up.
    Thank You.
