CDL Air Brake Question
Discussion in 'Questions From New Drivers' started by biggjerryc, Apr 5, 2012.
  1. biggjerryc
    biggjerryc Bobtail Member
    34
    5
    Apr 5, 2012
    lansdale pa
    I just got my CDL Class A but I didn't get the Air Brake Restriction taken off because I don't drive an air brake vehicle for the company I'm with. If I want to get the Air Brake Restriction taken off, I start by going to the DMV and taking the written test.
    Question: Do I have to retake my road test for the air brake certification?
    I think I do, but my test instructor said, he isn't sure, it isn't too often people get CDL Class S without Air brake." I called the DMV and the person I talked to didn't know either
  3. albhb3
    albhb3 Medium Load Member
    596
    279
    Nov 3, 2009
    so I was wondering does the back of your card state you have an airbrake restriction. I will say a guy I use to work with just had to do the airbrake and drive around. He didnt have to do any of the parking stuff however.
  4. biggjerryc
    34
    5
    Apr 5, 2012
    lansdale pa
    Yeah, it says it on the back.
  5. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    Yes. Air brake requires both a written and skills test.
  6. biggjerryc
    34
    5
    Apr 5, 2012
    lansdale pa
    Would you happen to know what that skills test cosists of? I already did a road test for a cdl class a vehicle. So is the air brake test just a general skills test? Or is it the driving exam all over again?
  7. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    Primary focus will be on the air brake portion of the pre-trip inspection, since that is what you are trying to add....however you must still pass the entire pre-trip inspection before they will take you out for a drive. The DMV can probably answer the questions about what all "driving" you will be required to do....
  8. ITS62
    ITS62 Light Load Member
    164
    69
    Apr 29, 2011
    Gilroy, CA
    There will be a written endorsement test.
    You will also need to take the air brake skill test in a truck, but you should not have to repeat the pretrip inspection, backing skills or driving test to get the endorsement. I would confirm with your local DMV. That is actually the easiest part once you know what they are looking for during the test.
    At Least in CA, the written, airbrake, pretrip, skills, and driving were all separate tests and you had to pass one to move on to the next, but if you failed one section, you started at the last test you passed, not from the beginning so I would be willing to bet you won't have to repeat the other tests you already passes. Worth doing if you wanna get full use from your CDL.
  9. biggjerryc
    34
    5
    Apr 5, 2012
    lansdale pa
    Ok. I am gonna go for it and take the written this Saturday.
    My uncle owns a trucking company and has offered me an OTR position. I am getting tired of my full time now so, I am thinking of taking it. I'd be doing pick up and drop.
  10. TonyUFN
    TonyUFN Bobtail Member
    13
    6
    Oct 22, 2008
    Gilmer, TX
    In IL, you have to take all elements again. The pre-trip basically gets limited to differences focused on the airbrake system but they do recheck lights, etc.
    All brake tests during pretrip are done(not just explained).
    Skills and Road tests are required as well. Measured right turn, pull-forward(measured stop), 150ft straight backing, and alley dock. However, they seemed to have changed the 'GOAL' and the 20ft pullup... Now you can stop anywhere while backing for the alleydock and GOAL... as long as you haven't already crossed 'hit the building' line. The change I noticed was that now you can get within mere feet of the box and get out and look. Previously, you could only do that before entering the initial 'dock area'; once you were inside that area you were committed.
    LOL, to me it looks like they made the measured stop boxes a bit smaller over the years ;)
    But hey... it Hell-inois, expect anything.
