Cb setup tips. All help/info welcome
Discussion in 'CB Radio Forum' started by PotholeMcBounce, May 11, 2021.
  1. PotholeMcBounce
    PotholeMcBounce Bobtail Member
    So I'm getting into setting up and learning about cb. Turned out that my company's shop no longer fools with cb installations due to being blamed for burning up cb's and such issues as that(understandable from business perspective).
    I'm driving a 2019ish international LT and it has the stock dual antenna setup with them mounted on the back of my sleeper.
    Purchased a cobra 29ltd classic(was on sale and im not versed in this area yet, so didn't wanna invest a chunk and burn up my investment due to ignorance). Installed it into the given slot in my cab. Tuned it up at time of purchase and all was well.
    Issue I'm having now is that when I engage to speak my antenna light is coming on. I hear others well for a couple miles out(currently in Kentucky mountains), but idk if im broadcasting. I've looked at the antennas and there's not really anything I can do to adjust/improve their setup. Thinking it may be a ground issue. Maybe need to get new antenna arrangement
    What yall thinking?
  3. Timin770
    Timin770 Road Train Member
    1,657
    1,757
    May 27, 2011
    Canton, GA
    It is difficult to get a proper radio check these days. Sadly, your best chance is to ask for a radio check at a truck stop. The best response you'll get is, "Its workin' driver"
    The CORRECT response would be "Driver I'm at the 37 mile marker and you sound good"
    One trick I do (likely not feasible for most drivers) is turn on my home base station and turn on a nearby voice-activated recorder. I then transmit at known distances as I drive away from home. I review the tape later to ascertain my transmit quality and range.
    JForce28, Badmon, Blue jeans and 3 others Thank this.
  4. Meteorgray
    Meteorgray Heavy Load Member
    754
    597
    Jan 1, 2016
    Another alternative is to get a buddy with a CB to talk to you as you drive away from him, noting the mileage. Although communication distance is dependent on many factors, some of which are constantly changing as you drive through various areas, it should give you an idea of how your outfit is doing. It's a good test for your buddy's as well, because it takes two to tango.
    Also, I'd get a $25 SWR meter with a two- or three-foot coax connecting cable and connect it between your radio and antenna. Your radio's antenna light may or may not be significant, but you should shoot for an SWR or 1.5 or lower.
    PotholeMcBounce Thanks this.
  5. 50WT
    50WT Road Train Member
    2,035
    17,534
    Dec 26, 2015
    I just key down a say , wow lady you better put some clothes on, you're going to cause a accident.
    You'll know if you're getting out.Lol
  6. Timin770
    1,657
    1,757
    May 27, 2011
    Canton, GA
    Quite funny but actually a good idea. Any mention of nude ladies around horny truck drivers is sure to get responses
  7. craig_sez
    craig_sez Road Train Member
    5,564
    2,709
    Sep 5, 2013
    novascotia,Canada
    No one addressed his red light...
    Lets see the responces for the fellas binder..
    42Zero_Pizzaman_Tampa Thanks this.
  8. Patrick615
    Patrick615 Light Load Member
    50
    39
    Jun 10, 2018
    First thing you gotta do is get a coax, nothing fancy, just Wilson coax from a truck stop, a cheap swr meter, truck stop and a good antenna like a firestick. A 5/8 wave is your best bet. Try to get your swr @1:1-1:3 on 1-20 and 40. Order up a connex 3300 or a general lee, a road devil mic you’ll be walk-in the walk and talkin the talk.
  9. craig_sez
    5,564
    2,709
    Sep 5, 2013
    novascotia,Canada
    Forget the road devil..Dont need a power mic if tuned the right way..
    A sr 198 adjusted with radios freq responce or a d104 cause then you can atleast adjust the tone some..
    In either case a power mic is pointless if its been tuned....Thats that mic gain is for..
    Diesel Dave Thanks this.
  10. Night Stalker10
    Night Stalker10 Road Train Member
    1,668
    1,243
    Jun 26, 2017
    My first thought was poor location for the antennas. The OP didn't say what brand or height the antennas are. It would have been nice to see a picture of the antennas to see if it could give us a clue. Plus how far apart the antennas are. Not sure when the OP said "Tuned it up at time of purchase" meant the radio, or antennas. Be nice to know what an external SWR meter shows about the antenna system. Or better yet an antenna analyzer. Of course its been a month now, so who knows if the problem has been resolved.
  11. Patrick615
    50
    39
    Jun 10, 2018
    A road devil is a d104. Same components as a regular d104 except the rd is noise canceling
