I recently purchased a new Cobra 29 ltd chrome. I took it to a cb shop and had it peaked and tuned along with purchasing a new wilson 1000 magnet mount. He said I should be able to get out about 10 miles but found that I average about 2 or 3 miles. Another driver said I could probably use a new mic since im using the stock mic but im not sure. He said it sounded like I was far away and we were within 2 miles of eachother. I adjusted the squelch and it was little better but not sure what's wrong. The guy I spoke with said his radio was stock with a terminator 2 antenna and his stuff worked great. Any advise?
cb radio. no distance
Discussion in 'CB Radio Forum' started by leftlayne, Sep 13, 2018.
Page 1 of 9
Tell us about the vehicle you have that magnet stuck on, and where is it placed on the vehicle?
Did the tech explain what he did to the radio and how he improved the performance over stock?rabbiporkchop Thanks this. -
Is the antenna wire pinched where it comes into the vehicle?
It's mounted on a 2005 Dodge Dakota and the tech put it a little towards the front but more centered and the line is not pinched.
Did you have the cb shop match your antenna to your radio? If this is a new install, you need an SWR meter to check out your antenna system. I’m not sure if you already know about this, or if you are new to using a cb radio.
Yeah the guy set my SWR meter an matched my antenna to my radio
Okay, that probably leaves the radio or the antenna. Unfortunately I’ve never owned a Wilson 1000 mag mount antenna, but I would think it should talk farther than 3 miles. Some guys on this forum own the Wilson 5000 antenna and seem to get 10 miles.
Now if a radio isn’t aligned correctly, it won’t talk very far either. You should be able to talk at least 5 miles or more with a Cobra 29 set at 4 watts for transmit power, with a good antenna and coax. Also your surrounding environment can effect your distance too. -
Well this morning I was at work and I talked with a guy from north liberty indiana, 20 miles away. When I'm traveling the interstate it doesn't seem to get out. I live 11 miles from a pilot so I would like to think I should be able to reach someone more than 3 miles out.
That doesn't seem right though. Peaked and tuned with a Wilson 1000, 20 miles away? Dude said he was in his big truckLast edited: Sep 14, 2018
That’s interesting. It makes me think there’s something going on with your antenna. About the easiest way to check, would be having someone ride along with an antenna analyzer. Just to see if the impedance and SWR drastically increases while driving down the highway. If you haven’t already done this, you may need to make sure your antenna is tight on the magnet mount. Of course I realize not everyone knows someone, or has an antenna analyzer, but they sure are a handy tool when needed.
Want to get out farther than 2 or 3 miles? Get a amplifier and see 15-20 miles range just about anytime you turn on the radio...
I have a President McKinley radio in my Tacoma, and a 1x2 amplifier and regularly can talk 20+ miles with the set-up... President McKinley is just a basic 4w CB Radio similar to the Cobra 29 as for as power go's, but when paired with my 1x2 amp, that 4w's turns into closer to 400w's...So if I can hear a station, I usually have no problem getting back to them...
Your antenna is just as important for distance as the power your running, if not more-so! So first off, I'm not a big fan of base loaded, and magnet mounted antenna's... The 102" whip antenna is going to be about the best you can get, but the problem is, it needs to be mounted on the roof to work to it's full potential...(which is the biggest problem since most can't drive around town with a 9' antenna sticking up off the top of the roof.)
I run a single-coil Predator 10K which is a center loaded antenna and get great results locally and with DX contacts... I can talk from the west side of Dallas to some friends over east of the Mesquite/Garland area 20+ miles away...With a Wilson 5000 magnet mounted antenna I couldn't even hear those guys at that distance...much less them hear me.
Just this afternoon on the way home I was in the Oak Cliff area west of Dallas and talked to a guy that was crossing over Lake Ray Hubbard East of Dallas...As the crow-fly's, that was over 25 miles during rush-hour.
Page 1 of 9
