cb radio for tacoma
Discussion in 'CB Radio Forum' started by friedtaco, Feb 10, 2013.
  1. friedtaco
    friedtaco Bobtail Member
    ive gone ahead and picked the uniden pro520xl unit. now the antenna is where the confusion comes into play. its the most important part i know this. i heard flex or whip antennas are useless, i dont know. so length im looking for is 4feet, id prefer flex but i want to be able to reach out atleast 4miles. any ideas of what to look at? wilson,firestik are good brands i heard
  3. MsJamie
    MsJamie Road Train Member
    I personally drill a hole in the roof and put an NMO base there, then put a Larsen NMO-27 antenna on it.
    If you feel at all nervous about drilling holes in your car, then take it to a place that sells business radios. They can do it in about half an hour for about $20 + mount ($15-$20).
    The only thing I've run that works better is a 102" whip.
  4. Voltrucker
    Voltrucker Medium Load Member
    467
    133
    Sep 24, 2012
    West TN
    Wilson 1000 mag mount.
  5. friedtaco
    so im looking at wilson 100 think thats more than ill ever use. whats bad about the 500 or lil wil? i even saw they have fiberglass antennas, havent heard much about those any pros or cons you know of?
  6. Budha
    Budha Light Load Member
    142
    138
    Jun 23, 2012
    Here
    Depending on where you live or drive , fiber glass antennas dont last long when it comes to obstacles....ie...trees..limbs...garages...etc.
  7. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    My 2001 Toyota Tacoma with a 55 built antenna (samething as the Fatboy R6) on a riser...Antenna is about 7' tall (give or take)
  8. Voltrucker
    467
    133
    Sep 24, 2012
    West TN
    I had a Little Wil one time, never did like it. Couldn't receive or transmit good.
  9. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
    Who told you whip style antennas are useless?????
    FWIW I run a 108 steel whip on the back of my S-10 and I can talk on 4 watts where others have to start reverting to running power. Yet when I hit a tree branch my whip just bends over and takes it.
    4 miles is nothing for me...often I can talk easily 7-9 miles. Again on 4 watts of power. Height is might when it comes to antennas, as is having the "right" antenna for the job. In this case, the "right" antenna for CB for 1/4 wave is 9 ft. tall.
    The Lil Wil is "ok". That's what I started out on. But the shorter the antenna, the more your range is hindered. A Lil Wil has a 36" whip. The 1000 has a 62" whip. You'll talk farther with the 1000. I actually did talk 7 miles on the 1k once on 4 watts, but with the Lil Wil maybe 3 miles.
  10. Tricky Rick
    Tricky Rick Light Load Member
    177
    91
    Oct 25, 2010
    Northwest Mississippi
    I may have just been lucky, but my K30 magnet mount talks about 5 miles and hears about 11 most of the time. The whip was adjusted until I got a 1.1 to 1 SWR. Trimmed off about 4 inches to get the SWR really close. Works on both my Nissan Maxima and Chrysler mini van.
  11. mike5511
    mike5511 Road Train Member
    3,139
    1,523
    May 15, 2011
    NW Arkansas
    A Little Wil is what you use for a quick temporary install; I've got two of them. I ran a mag mount on my pick-up for a while. The paint under the magnet will eventually go bad, or become scratched up, plus the you have the coax flapping around if your not careful. My solution was to drill a hole in the middle of the roof and mount a Wilson 1000. No regrets and works great. FWIW, a whole in the middle of a pick-up roof that has the proper rubber plug inserted at trade in time, will not lower your trade in value............go for it!
    MsJamie: You think the Larsen will out perform the Wilson mounted like I stated above? They are only rated for 200 watts, so that is a deal breaker for me in the pickup, but I'm curious as to how they would match up head to head. The Wilson is the longer antenna if I'm not mistaken........?
