CB install? Wiring question?
Discussion in 'CB Radio Forum' started by Rowdy Finn, May 21, 2012.
  1. Rowdy Finn
    Rowdy Finn Bobtail Member
    44
    4
    Oct 7, 2010
    Eastern NC
    Bought a new-to-me/used Freightliner. I am trying to install my General Lee I got from Radioactive Radios. Radio has a plug with + and - wires. Tractor CB hole has an old connector that won't fit my radio. The wires in the hole are yellow and yellow? No differentiation between the two yellow wires. How do I know which wire is + and which is - ? Also, looks like someone spliced into the wires to hook up a fan hanging over the dash? Looks like they cut the fan wires sometime down the road. I don't see any wires that are separate to power the fan. Could splicing in the fan harm the radio? Maybe cause static thus the cut wires?
  3. ramkatral
    ramkatral Heavy Load Member
    858
    408
    Dec 27, 2010
    Tryon, NC
    Yes it could cause "dirty power" as in noise in the radio. I doubt it would hurt it. I wouldn't recommend it. One of those wires should have a black stripe. That's your ground wire.
    Remove the spliced wires and keep that power for your radio only to keep it clean.
    If there is no black stripe, use a multimeter to find the hot wire.
  4. Jeremyc
    Jeremyc Light Load Member
    266
    90
    Feb 29, 2012
    The Great Lakes
    Um, I wouldn't hook anything to those old unmarked wires.
    Find out where they go and get rid of them and then run your own wiring.
    WA4GCH Thanks this.
  5. ramkatral
    858
    408
    Dec 27, 2010
    Tryon, NC
    Factory freight liners often have yellow wires factory stock. The wire is safe to use.
  6. Jeremyc
    266
    90
    Feb 29, 2012
    The Great Lakes
    Yeah, I guess you're probably right, I just didn't like the fact that he said they had already been spliced in to.
  7. ramkatral
    858
    408
    Dec 27, 2010
    Tryon, NC
    Me neither. I'd cut the wire back where the splices are and hook my cb power adapter to it. That way you have no exposed copper.
    WA4GCH Thanks this.
  8. Rowdy Finn
    44
    4
    Oct 7, 2010
    Eastern NC
    OK,thanks guys!
  9. ramkatral
    858
    408
    Dec 27, 2010
    Tryon, NC
    Just get a cheapo little crimper tool and a couple of splicers. They are color coded to size. Red should be the right size for cb wires. Blues could be made to work with extra crimping. Yellows are way too big. I'm not a CB expert but I did used to professionally install car audio lol.
  10. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    AH ....:biggrin_2559:
    The old crimp connector trick :biggrin_25513:
  11. ramkatral
    858
    408
    Dec 27, 2010
    Tryon, NC
    Yup. Crimp connectors used to be my hero when I installed audio systems lol.
    Used a few inside of computers too heh heh. Sleeve the wire and you'd never know.
